Libraries - Hidden and Empty Fix
Page 1 of 4 123 ... LastLast
    How to Fix Libraries when Hidden and Empty in Windows 7 and Windows 8
    When you open your Libraries in Windows Explorer and it is empty or the libraries are hidden, then this will show you how to fix them if clicking on the Restore Default Libraries option did not help.
    EXAMPLE: Libraries Hidden and Empty
    NOTE: If you see faded library folders, then this also means that they are hidden.
    OPTION ONE
    Fix Hidden Empty Libraries with a BAT File
    NOTE: This does the same thing as OPTION TWO below, but automatically.
    1. Click on the Download button below to download the the file below.
    Unhide_Libraries.bat
    Download
    2. Unblock the downloaded BAT file, then run it.
    NOTE: You may notice a quick flash of the command prompt opening and closing at it runs.
    3. Log off and log on, or restart the computer to apply.
    OPTION TWO
    Fix Hidden Empty Libraries in a Command Prompt
    NOTE: This does the same thing as OPTION ONE above, but manually.
    1. Open a command prompt.
    2. Copy and past the command below into the command prompt, and press Enter.
    attrib -h "%AppData%\Microsoft\Windows\Libraries\*.library-ms"
    3. Close the command prompt.
    4. Log off and log on, or restart the computer to apply.
  1. Posts : 8,398
    Great tutorial, Shawn. Well done.
  2. Posts : 72,052
    Thank you Jaidyn. I noticed this happening a bit more lately with folks here, and thought it best to have a separate tutorial on it. :)
  3. Posts : 2,298
    Great Tutorial Shawn - Does this affect the C:\Users\*User Name*\ ?
    Where all the other Folders are (Like Vista)
  4. Posts : 72,052
    Hello Josh,
    Sorry, but no. It only affects the library folders for the current user. You could use the command in step 23 of Option Two in the tutorial below for the user folders instead though. :)
    User Folders - Restore Default Location
  5. Posts : 7
    windows 7 Home Premium x64
    thanks
    Thanks for the help, that fixed my hidden (faded) folders. Any idea why the library folders suddenly become hidden? I didn't have this problem before installing McAfee, just wondering if that is causing the issue.
  6. Posts : 72,052
    You're welcome Laurie, and welcome to Seven Forums.
    There's not an exact cause other than something had changed the libraries attribute settings to be hidden. I would recommend to scan your system for malware using the free program MSE and/or MalwareBytes just to be extra safe though. :)
  7. Posts : 1
    Windows 7 Professional x64
    Thank you so much for posting this simple fix! I had tried restoring to earlier backups, and searched for solutions without success for some time before finding this forum. None of the other solutions I tried worked, but this simple fix worked immediately.
  8. Posts : 72,052
    You're most welcome rwright, and welcome to Seven Forums. :)
  9. Posts : 5
    Windows 7 Home Premium 64-bit
    Wonderful Fix!
    I am not using McAfee (Symantec Endpoint Protection) like others that I have seen with this problem, but this happened to me, too. It was either while I was trying to view hidden folders, or when I was changing the permissions to "full control" in the same folder properties window. Either way, all files disappeared and "restoring default libraries" did not help. System restore was also useless so it was "undone". I went into the Folder Options in the Control Panel and selected to view all hidden files. I can now see everything but they are all still in "hidden" mode. Thanks to your fix program, I can now see my libraries.
    My C:\Users\*User Name*\ is still hidden and so are all my files in the libraries. Can this be fixed?
    Could this be indicative of a different/bigger problem??? Thanks for your expertise and help.
    Last edited by TamaraG; 04 Nov 2011 at 19:34. Reason: changed outcomes as i worked through the problem
