Libraries - Hidden and Empty Fix
Page 4 of 4 FirstFirst ... 234
  1. Posts : 72,050
       #30
    I wouldn't think your CPU or RAM would cause this.
    If it keeps up, then you might consider reinstalling Windows to start fresh.
  2. Posts : 9
    Win 7 Ultimate, SP1 64-bit
       #31
    Ok.
  3. Posts : 9
       #32
    Brink, I am confident that I now know what the problem is. As you can see from the screenshot that it's a COM Surrogate memory issue, and I am currently reading up on another sevenforum as to what to do. I'm not familiar with this issue, and I read where it might be due to a corrupt media file. Any ideas?
    Attached Thumbnails Attached Thumbnails Libraries - Hidden and Empty Fix-com-surrogate-memory-hog.jpg
  4. Posts : 72,050
       #33
    I'm afraid that I'm not sure about the COM Surrogate issue, but there's definitely an issue with it.
    It would be worth creating a new thread for this issue.
  5. Posts : 9
       #34
    Well I uninstalled the update that was said to be the issue and deleted the file that I believe was the problem, and I believe the issue is resolved. So Thank You for all the help. I don't think I need to create a new thread for it.
  6. Posts : 72,050
       #35
    Great news Gras. Which update caused it?
  7. Posts : 9
       #36
    KB2670838
    Here's the link to the forum:
    dllhost.exe (COM Surrogate) consumes all CPU memory
  8. Posts : 72,050
       #37
    Thank you.
  9. Posts : 9
       #38
    My apologies about this issue, As you know I thought the issue revolved around Libraries as your tutorial explains; so I am sorry I did not post a new thread or a response in the other forum. But thank you for your support.
  10. Posts : 72,050
       #39
    No worries. :)
