Do you get a AutoPlay pop-up when you connect or insert other forms of devices/media?
If you have not already, see if turning off AutoPlay completely and turning back on may toggle it to work again.
In addition, double check with the tutorial below to see if your AutoPlay may have been disabled by using OPTION ONE to enable AutoPlay.
AutoPlay - Enable or Disable
