Windows 7: Gathering a Startup, Shutdown, Sleep, Hibernate, or Reboot Trace
04 Nov 2012   #60
Bob Pickering
windows 7 home premium 64
Quote   Quote: Originally Posted by cluberti View Post
Hmmmmm - let me see if I can get creative with you. Give me a few days to see what I can do.
Have you been able to come up with a solution?
04 Nov 2012   #61
cluberti
Sorry - Sandy came through and I'm just digging out. Once I get stable internet access and get back to regular work schedule, I'll get a write-up done.
04 Nov 2012   #62
Bob Pickering
Thanks for the reply. No problem with delay. Very sorry to hear about Sandy. The situation had a lot of coverage on TV even here in South Australia. Much safer here and weather overall is far better. Perhaps you should migrate and leave the snow and cyclones behind? I hope you and your family/friends are all ok. Bob
08 Nov 2012   #63
jaguar85
Windows 7 Home Premium 32 bit
Gregrocker recommended me to post my boot trace here for my booting problem.
Can someone please trace by boot and let me know what is the problem and recommended solution for it. Link for my boot trace file - shutdown_BASE+LATENCY+DISK_IO_INIT+DISPATCHER+DRIVERS+FILE_IO+FILE_IO_INIT+NETWORKTRACE+PERF_COUNTER +POWER+PRIORITY+REGISTRY_1.rar
Thread for my problem - Boot time 5-6 minutes & after booting applications freezes for 1 min
Main problem is my Intel(R) HD & NVIDIA display drivers are interfering and causing windows to resume slow.
28 Nov 2012   #64
Bob Pickering
Cannot shutdown/restart
Quote   Quote: Originally Posted by Bob Pickering View Post
I am still hoping that someone can fix my problem with inability to shutdown/restart
03 Dec 2012   #65
powerplyer
64bit
Guys I ran the boot trace as instructed and as soon the system rebooted it blue screened. I tried to reboot several times and the only two options I get are Start-up Recovery and Boot Normally. Please help. The system keeps on rebooting. I can get to the command prompt under Start-up Recovery x:\. Is there a way to stop running the boot trace.
03 Dec 2012   #66
gregrocker
Boot into System Recovery Options on Win7 DVD or System Repair Disk to run Startup Repair repeatedly. It should offer to System Restore for you, but if not and it won't start then run it manually, working back as far as it takes to start Win7.
If this fails work through these steps for Troubleshooting Windows 7 Failure to Start that try everything to repair Win7 to start leading up to if necessary rescuiing your files to run Factory Recovery or get the superior Clean Reinstall - Factory OEM Windows 7 which steps are same for retail.
30 Jan 2013   #67
dita
7 64 home premium
Hi cluberti,
I have recently experienced a sudden degradation in my windows 7 boot time, and have performed a boot trace hoping to determine if there are any underlying hardware issues, since I do not believe I have made any changes on the software side. Would really appreciate your assistance in interpreting the data found in the trace log.
Link to etl file: http://sdrv.ms/12aeLD9
Link to original thread: Thread
Thank you very much!
31 Jan 2013   #68
Bob Pickering
Hopefully now is a good time for you to be able to look at my problem once again. To reiterate, I cannot get Windows 7-64 to shutdown from the start menu. This has been going on for some months. I did a restore to an earlier point, which fixed problem for a day or so, then it resumed. Haven't been able to instal and run the tools you outlined. Refuses to work despite numerous tries.
31 Jan 2013   #69
Bob Pickering
any news yet?
I still haven't been able to load the SDK successfully. I will attach the log file which may help. The computer will not shutdown from the start menu, only by hard shutdown with the power button. I see that my post a few minutes earlier now appears. I thought it had gone into outer space. Anyway, if you read both, it should help. Many thanks. p.s. Turned 70 last Monday, but I am still a junior member. Ha!
Dual Monitors reset when S.Saver/sleep/reboot/hibernate
Dual Monitors reset when Screensaver/sleep/reboot/hibernate & Returning to single monitor cause a hissy fit tantrum by win 7 I have a problem with Win7 and my dual monitors setup. I have 2 SyncMaster 245T monitors, connected via DVI cable to a NVIDIA GeForce 7900 GTX card. I have downloaded...
General Discussion
Computer freeze/BSOD/reboot after sleep/hibernate error 41
Hello! As the title says. The computer is newly built, component list you will find bellow. Anyhow, never had this issue with any other computers i have built in the past. Got the problem as soon as i had installed windows 7 ultimate and put all the parts together (obviously). The problem is...
BSOD Help and Support
Laptop will not sleep, hibernate or shutdown
For the past few days Windows refuses to shutdown. Everytime I select the sleep, hibernate or shutdown options it will reboot/reawaken straight away. I have tested the RAM which had no problems, I reinstalled Windows completely which didn't help & I checked power settings in BIOS to disable...
Seven BSOD Shutdown, Hibernate or sleep
Hello, So I am stumped I have searched the net over and over. So I have come here for some advice. Win 7 - x86 (32-bit) or x64 ? -- x64 - the original installed OS on the system? -- 32 bit vista - an OEM or full retail version?
Leave On, Sleep, Hibernate or Shutdown
When you go to bed at night, what do you do with your PC?
Chillout Room
