Thanks for quick reply. I've done both.
I'm with two h.disks. First is a SSD Samsung (a clean install). Second WDC WD7500BPKX which is a clone restore with Macrium.
Both with an Os W7. In Bios Ahci enable but it doesn't show if is for both. Can it be only for one of them?
I was trying to enable the power option in the second disk (WDC) for testing performance.
Unfortunately at this moment I don't know if it support Himp/Dimp.
If I let the key with attribute ....2 what exactly it means? Is it okey to let it even if is not showing as an option in Power options? Thanks
It won't hurt anything to leave it enabled (set to 2) if you like.
You might see if merging the .reg file again may help in case one of the approval prompts wasn't approved by you by mistake.
Ok. you are right. There are bigger problems than this in life..
Maybe you know if the dword value is 1 or 0 what it brings?
Anyway... Have a good time... and thanks (again..:))
Hi brink will i be able to successfully do this on my system?
Hello Chris, :)
If your internal drives have a SATA connection in AHCI mode, then you should be able to.
For Windows 10: Power Options - Add 'AHCI Link Power Management' in Windows 10 - Windows 10 Tutorials
I dont have the option to change that setting in my bios but heres a picture of my controller
and what setting would work best for me?
