AHCI Link Power Management - Enable HIPM and DIPM
  1. Posts : 72,046
    notis said:
    Thanks for tutorials Brink.
    I merge the Add "AHCI Link Power Management-HIPM/DIPM" .reg but I could not get the power options. Looking in the registry I found the key with attribute dword ...2
    I'm speaking for Dell xps sata3 ahci. Any idea? Do you advice maybe to remove it?
    Hello notis, :)
    Double check the red warning box at the top of the tutorial to see if anything may apply.
    If everything checks out, then you might see if restarting the computer may help.
  2. Posts : 141
    Windows 7 Home Premium x64, *W7 Prem. x64
    Thanks for quick reply. I've done both.
    I'm with two h.disks. First is a SSD Samsung (a clean install). Second WDC WD7500BPKX which is a clone restore with Macrium.
    Both with an Os W7. In Bios Ahci enable but it doesn't show if is for both. Can it be only for one of them?
    I was trying to enable the power option in the second disk (WDC) for testing performance.
    Unfortunately at this moment I don't know if it support Himp/Dimp.
    If I let the key with attribute ....2 what exactly it means? Is it okey to let it even if is not showing as an option in Power options? Thanks
  3. Posts : 72,046
       #12
    It won't hurt anything to leave it enabled (set to 2) if you like.
    You might see if merging the .reg file again may help in case one of the approval prompts wasn't approved by you by mistake.
  4. Posts : 141
    Ok. you are right. There are bigger problems than this in life..
    Maybe you know if the dword value is 1 or 0 what it brings?
    Anyway... Have a good time... and thanks (again..:))
  5. Posts : 72,046
       #14
    1 = off
    2 = on
  6. Posts : 297
       #15
    Does this work on Windows 10?
  7. Posts : 72,046
       #16
    Yes. It'll be the same in Windows 10. :)
  8. Posts : 10
    Microsoft Windows 7 Home Premium 32-bit 7601 Multiprocessor Free Service Pack 1
       #17
    Hi brink will i be able to successfully do this on my system?
  9. Posts : 72,046
       #18
    Hello Chris, :)
    If your internal drives have a SATA connection in AHCI mode, then you should be able to.
    For Windows 10: Power Options - Add 'AHCI Link Power Management' in Windows 10 - Windows 10 Tutorials
  10. Posts : 10
       #19
    I dont have the option to change that setting in my bios but heres a picture of my controller
    and what setting would work best for me?
    Attached Thumbnails Attached Thumbnails AHCI Link Power Management - Enable HIPM and DIPM-capture.png
