Index Locations - Add or Remove
  1. Posts : 72,059
    Jaime,
    Sorry, I wish there was a way, but there's just not a way to add a removable SD card to be indexed.
  2. Posts : 2
    Windows 8 x64
    Can i Add an local network location? Because i want to have a libary that will be with local network location and i have to index it first...
  3. Posts : 72,059
       #12
    Hello Fszeker, and welcome to Seven Forums.
    You might see if using the Win7 Library Tool program may work for you to have it as a library without having to index it instead since it adding a network location to the index is a bit of work to do.
  4. Posts : 2
    Windows 8 x64
    Thanks. Helped. Even on Windows 8.
  5. Posts : 72,059
       #14
    You're most welcome Fszeker. :)
  6. Posts : 5
    windows 7 ultimate x64 SP1
       #15
    But the problem is, even if I exclude folder from a drive its still showing up in the startup search. The folder only. Anyway to remove a folder from index?
  7. Posts : 72,059
       #16
    Hello Salmanshah, and welcome to Seven Forums.
    If you just recently excluded the folder, or unchecked it, then you may need to rebuild the index to update it and not have the folder included in search results.
  8. Posts : 5
       #17
    Thank you, i have rebuild the index but no use. still the same.
  9. Posts : 72,059
       #18
    Salmanshah,
    Just to make sure that I'm on the same page as you, could you explain what you mean by "startup search" and post a screenshot of it?
  10. Posts : 5
       #19
    I meant this:
