Index Locations - Add or Remove
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 43
    win7_home_64
       #30
    brink hope you can help .... I have to places, I cannot remove from search. No coresponding folders are displayed. I think it is, because the coresponding folders dont exist anymore (comes from a restore of C: ).
    Is there any way to have all search locations reset/deleted ...
  2. Posts : 72,096
       #31
    Hello 5ggggg,
    You might see if rebuilding the index may help.
  3. Posts : 43
    win7_home_64
       #32
    no didnt help .. I tried also deactivating the service, deleting the search folders itself ... as said somewhere in the registry it stores those locations where the corespondig folders dont exist anymore ...
    I also tried the promlems solver ...
  4. Posts : 43
    win7_home_64
       #33
    it looks (acording to MS) that WinSearchIndexer cant deal with juntions. I had added a subfolder created under such a junction to the index. But as the indexer doesnt show the junction above it, one cant remove it.
    So I renamed my junction and created a folder whose name was like the one of my junction before and copied the subfolder into it. Now I could remove it from the indexer. Afterwards I deleted the new folder and renamed my juntion.
    Resumee: Dont add folders which are located under a junction to the indexer
  5. Posts : 72,096
       #34
    Yep, a junction point would do it. Thank you for posting back with your results and findings. :)
  6. Posts : 1,002
    XP Pro (x86) | 7 HP (x86) & (x64) | 7 Pro (x64)
       #35
    No "Indexing Options" on my Win7 Control Panel
    My Win7 32bit PC does not have "Indexing Options" listed on Control Panel
    I looked in "Performance and Information Tools" but it is not there !
    Where is "Indexing Options" hiding
  7. Posts : 72,096
       #36
    Hello Russell,
    Double check in Windows Features to make sure that you have Windows Search turned on (checked) like in the tutorial below to see if that may the cause.
    Windows Search - Turn On or Off
    Hope this helps for now, :)
  8. Posts : 1,002
       #37
    Thanks "Brink" :)
    I am rather late at acknowledging your guidance. Four months ... my apologies.
    Your tip worked .. my fault .. I forgot I disabled indexing.
    I am using "FileSearchEX" to search for contents ... and ... portable "Everything" to find files.
    FileSearchEX is perfect for me to search my 4,280 txt files (contents). Takes about 8 seconds for a result.
    "Everything" file-find results are immediate, as fast as I can type the file name.
    "Everything" portable does not inhibit external storage device removal (the integrated/installed version can cause problems when safely removing)
    I have assumed Start > Search ... uses the last index-list, so occasionally I do an "index update" -- haven't had any problems so far.
    Indexing slowed my PCs down considerably. A shame MS abandoned the WinXp "Find" dialog in Win7
    Thank you for an excellent forum
  9. Posts : 72,096
       #38
    You're welcome Russell. I'm happy to hear that you got it sorted. :)
  10. Posts : 12
    hi it says 0 items indexed and show all locations is greyed out.
    could this be because i don't have multiple drives and only one essential C: drive for my computer? also it says 0 items indexed. the most important thing is, How do I index things OUTSIDE my my C: drive, like Libraries, for example: Downloads, Music, Folders made outside of my C: drive, and... music/videos. system specs are
    Computer Manufacturer/Model NumberEdit Value
    HP
    OSEdit Value
    CPUEdit Value
    (3.00 GHz) AMD Athlon II X4 640 22 °C Propus 45nm Technology
    MotherboardEdit Value
    FOXCONN 2AB1 (CPU 1) 33 °C
    MemoryEdit Value
    6.00 GB 5.75 GB usable.
    Graphics Card(s)Edit Value
    HP S2031 (1600x900@60Hz) 2943MB ATI Radeon HD 4200 (HP) and my hard drive is barricuda. i copy and pasted my sytem specs because a notification of this website said it'd help admins/IT people to help me by providing system specs, thancs
