Wake Source - Read Event Viewer Log
Page 3 of 3 FirstFirst 123
  1. Posts : 339
       #20
    Oh, sorry. The computer went into hibernation at 2:31 so the first item is it.
  2. Posts : 72,050
       #21
    If you don't use a proxy, then as a test, see if disabling the WinHTTP Web Proxy Auto-Discovery Service service helps to stop it from waking the PC.
    Services - Start or Disable
  3. Posts : 339
       #22
    Thanks, Shawn!
  4. Posts : 339
       #23
    Actually, doesn't it look like that started so that the Windows Modules Installer could start? I think it runs on a schedule but haven't been able to find it, nor could I find anything was installed last night.
  5. Posts : 1
    Windows 7 Enterprise x32
       #24
    thank you so much, because this solved my problem!!
    trying so many things suggested, but nothing worked. and now i know why.
    i installed an .exe file (on purpose).
    and now i found out that .exe file is waking my system up.
    it's a decent program, but for fun, i don't really need it. so i just uninstalled it.
    thank you, i would never figure this out on my own!!
  6. Posts : 72,050
       #25
    I'm glad it was able to help Lona, and welcome to Seven Forums. :)
