Windows 7: System Info - See Your System Specs
15 Sep 2011   #60
agibson8891
Thank you Brink for all your help and patience in my lack of computer knowledge. It has been so frustrating obtaining answers to my issues and even though I stress with each post my limited knowledge, the usual replies are difficult for me to understand. I have taken my computer to Best Buy 3 times in the last year (to the tune of $900.00 total, which is slightly less than what I paid for the computer) and have had it stripped to factory condition 3 times, but the remote control problems still reoccur. So naturally I am at my wits end and am at a loss as to what I can do to get help. I can't access any functions relating to system boot (even if I could, I wouldn't know what to do with it).
15 Sep 2011   #61
Brink
64-bit Windows 10 Pro
You're most welcome Gibson. I hope your issue will get a solution soon. :)
16 Sep 2011   #62
randallrivy11
Microsoft Windows 7 Ultimate 64-bit 7601 Multiprocessor Free
CyberZeus this is gonna be a dumb question but im gonna ask it anyway does this program allow u to change ur specs to say what u want it to say when u click system in the control panels
16 Sep 2011   #63
Brink
Hello Randall,
If you mean with the program, then no.
If you mean your system specs here at the site, then yes.
14 Oct 2011   #64
BKeadle
Windows 7 Pro 32bit
Nice tool - would be even nicer if there was a single button that would pre-populate all the system information instead of having to do each entry individually.
16 Oct 2011   #65
7use
64 bit
I have windows 7, sp1 with latest updates. 64 bit.
Unable to run this tool. Please advice.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SystemInfo.lblMotherboardSummary.LoadSummary()
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.239 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SystemInfo
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///F:/Tools/SystemInfo.exe
Win32 Version: 4.0.30319.235 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.236 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Core
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Management
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
16 Oct 2011   #66
CyberZeus
Windows 7 Ultimate x64 SP1 clean install
Quote   Quote: Originally Posted by BKeadle View Post
Hi Bkeadle and thanks for your appreciation.
The problem of what you're asking is that there is not "direct link" between my application and SF System Spec page. I have to ask Shawn if it'll be possible with some kind of hidden POST url to populate System Specs form.
16 Oct 2011   #67
CyberZeus
Quote   Quote: Originally Posted by 7use View Post
Hi 7use and welcome to Seven Forums!
I think there is a problem in retrieving motherboard data of your hardware. I'm going to add error handling in the next version, so you'll be able to use my tool.
CyberZeus
16 Oct 2011   #68
Brink
Quote   Quote: Originally Posted by CyberZeus View Post
Sorry, but it wouldn't be possible to allow anything to populate your sysem specs automatically here at Seven Forums due to security reasons. We would not allow access like that. Sorry.
16 Oct 2011   #69
CyberZeus
Quote   Quote: Originally Posted by Brink View Post
I thought so, no problem.
System Specs?
I noticed a day or so ago that when I clicked on "My Specs' button on bottom of a post that it said to update them so did kinda do a couple of them but that notice is still there. Anything I left blank is because I don't know the answer. When I first did My Specs months ago I used some download...
Chillout Room
Processor info is showing wrongly in system info after changing MB
Yesterday I bought a new mother board for my PC my Processor model is AMD Athlon II X3 440 Triple Core Processor, but after changing Mother Board in system information it's showing my Processor as AMD Phenom II 4 B40 four core processor. I don't know why it is showing like this. Is this dangerous...
Hardware & Devices
Where do i find the info for my system specs?
Uhmm hello, Lol just a compter noob talking, but uhm.. where can I find the info for the system specs fields?
General Discussion
System Specs for Win 7
:cool: Any improvement suggestions?
General Discussion
