1. Click on either Download button below to download and save the
SystemInfo.exe file to your desktop.
2. Run the
SystemInfo.exe file.
NOTE: This is a standalone .exe file that only runs and does not install anything on your computer. If you would like to stop getting the Run prompt, then unblocking the SystemInfo.exe file will stop it.
3. After System Info loads, you will see a summary of your system's information.
NOTE: There's a Edit System Specs link at the bottom right that will take you to your system specs here at Seven Forums.
4. Do either
step 5 or 6 below for how you would like to fill out your
system specs at Seven Forums.
5. To Automatically Fill Out your System Specs at Seven Forums
NOTE: This step can only be done using Internet Explorer.
A) In System Info, click on
Options (menu bar),
Settings, select (dot)
Automatic Mode, and click on
OK. (see screenshots below)
B) Click on the
Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
C) If you are not already, log in to Seven Forums in the new IE
Seven Forums' Site window that just opened. (see screenshot below)
D) Click on the
Set info button at the top left corner to automatically enter the information from
System Info into your system specs at Seven Forums, then click on the
Save Changes button at the bottom to save them. (see screenshot below)
6. To Manually Fill Out your System Specs at Seven Forums
A) Clicking on each device icon will give you a pop-up with more detailed information about that device.
B) In System Info, click on
Options (menu bar),
Manual Mode, and click on
C) Click on the
D) You can now use the information in
System Info to fill out your
system specs at Seven Forums by clicking on the
button to the right of a system spec in
System Info to copy it to the clipboard, then right click in a
system specs field at Seven Forums like below and click on
Paste. When finished filling out your
system specs, be sure to click on the
