System Info - See Your System Specs
Page 14 of 16 FirstFirst ... 41213141516 LastLast
  1. Posts : 9,582
    Windows 8.1 Pro RTM x64
       #130
    Yep, they're there. :)
  2. Posts : 488
    Microsoft Windows 7 HomePremium 64-bit 7601 Multiprocessor Free Service Pack 1
       #131
    Gentlemen, could someone check the system info link. Can't seem to dload it.
  3. Posts : 1,711
    Win 7 Pro 64-bit 7601
       #132
    it works for me. I can download the tool.
  4. Posts : 72,058
       #133
    Hello AaLF,
    Your AV program may be blocking the download since it's an .exe file. I added a ZIP download option to see if that may work better for you.
    Hope this helps, :)
  5. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #134
    Thanks for the Tutorial/ Added to my signature :)
    Worked great by the way,
    Except for a few sections/ Case-pcu-cooling ?
    Cheers.
  6. Posts : 62
       #135
    thanks a lot
  7. Posts : 7
    windows 7 home premium 64bit
       #136
    Can't run SystemInfo.exe
    When I download and try to run SystemInfo.exe I get "Fatal error CLR error 8004005.
    What am I doing wrong?
    Frank
  8. Posts : 72,058
       #137
    Hello Frank, and welcome to Seven Forums. :)
    Usually this error is related to .NET Framework.
    Run a sfc /scannow command to see if you have any issues with corrupted system files, and if SFC can repair them if so. After SFC has sorted any issues, see if you are able to run the file.
  9. Posts : 29
    Windows 7 Ultimate Service Pack 1
       #138
    Didnt work for me...all windows are blank using Firefox 30
  10. Posts : 72,058
       #139
    Hello Win7jak,
    Did you use step 5 if you wanted to do it automatically?
    Otherwise, it'll just open your edit specs settings here at SF in your default browser when you only click on the Edit System Spec link in the System Info program.
    Hope this helps. :)
