#130
Yep, they're there. :)
Gentlemen, could someone check the system info link. Can't seem to dload it.
Thanks for the Tutorial/ Added to my signature :)
Worked great by the way,
Except for a few sections/ Case-pcu-cooling ?
Cheers.
thanks a lot
When I download and try to run SystemInfo.exe I get "Fatal error CLR error 8004005.
What am I doing wrong?
Frank
Hello Frank, and welcome to Seven Forums. :)
Usually this error is related to .NET Framework.
Run a sfc /scannow command to see if you have any issues with corrupted system files, and if SFC can repair them if so. After SFC has sorted any issues, see if you are able to run the file.
Didnt work for me...all windows are blank using Firefox 30
Hello Win7jak,
Did you use step 5 if you wanted to do it automatically?
Otherwise, it'll just open your edit specs settings here at SF in your default browser when you only click on the Edit System Spec link in the System Info program.
Hope this helps. :)
