System Info - See Your System Specs
Page 15 of 16 FirstFirst ... 513141516 LastLast
  1. Posts : 29
    Windows 7 Ultimate Service Pack 1
       #140
    Sorry for the long delay.
    No - I did not use step 5...I dont use Explorer but Firefox (just DL's FF 31).
    Thx
  2. Posts : 72,059
       #141
    That would be why then. Step 5 can only be used in Internet Explorer. Otherwise you'll need to manually copy and paste them.
  3. Posts : 43
    Windows 7 Ultimate x32
       #142
    not working, it shows error.
    Attached Thumbnails Attached Thumbnails System Info - See Your System Specs-255.jpg
  4. Posts : 72,059
       #143
    Hello Ganesh,
    That error means that you need to install .NET Framework 4.0 first. :)
  5. Posts : 43
       #144
    it says standalone installer, so will it require internet to install?
  6. Posts : 72,059
       #145
    It will require the Internet to download.
  7. Posts : 166
       #146
    Exporting
    Are the any exporting option with this?
  8. Posts : 72,059
       #147
    Hello Wyatt,
    If you're using this for the site, you could copy and paste to help make it easier.
  9. Posts : 166
       #148
    Brink said:
    Hello Wyatt,
    ok. thank you so much. you are truly a big help as well as a lot of others. thx a bunch
  10. Posts : 11
    SysSpecsOK-But will they auto-appear in my posts?
    Thanks for lucid explication of how to get all specs together - did that.
    Now I want to post - are they going to automatically appear in my post(s),
    or do I have to do something to make that happen?
    Guess I'm about to find out, huh... AbbyBoo
