Calculator - Perform Unit Conversions
This willl show you how to perform unit coversions in Windows 7 Calculator.
1. Start Calculator.
Click on
orbit and go to All Programs -> Accessories ->Calculator.
or
Click on
and search for Calculator and press Enter.
2. Calculator will start. There from the View menu select Unit Conversion. (Or press Ctrl + U )
Calculator will be changed a bit,and should look like this:
In first dropdown menu you can select what you want to convert (Temperature, Weight, Angle, Time...).
Second and third are to convert inserted values.
For example, I want to convert Degree Celsuis to Degree Farhenheit. After typing the value in Celsuis it will automaticly convert to Farhenheit.
That's all. If you don't want that Unit Conversion in Calculator you can turn it off, by selecting Bacis from View menu.
