hi i would like to know
i would like to enable or disable a device from device manager without opening device manger is there maybe a script or a shortcut
hi,
I've problems my laptop not being able to awake from sleep by the keyboard. I've tried to add keyboard to list devices can wake the system ("klawiatura" means keyboard). OS Win 8, 64-bit. I am the only user and have full administrator access.
there isn't power management tab in keyboard...
How to Enable or Disable DOM Storage "Cookies" in Internet Explorer and Firefox
DOM Storage is often compared to HTTP cookies. Like cookies, Web developers can store per-session or domain-specific data as name/value pairs on the client using DOM Storage. However, unlike cookies, DOM Storage...
is there a possibility to create shortcut (hotkey or another fast method) to disable and enable device (like in device manager)?
If not for all device, is it possible for built-in cam and/or microphone?
(preferred not by 3rd party aplications)
How to Enable or Disable the Device Manager MMC Snap-in
This will show you how to enable or disable all users on the computer from being able to open and view the Device Manager MMC snap-in window in Vista, Windows 7, and Windows 8.
You will need to be logged in as an administrator to be...
