Lock Computer - Add to Desktop Context Menu
    How to Add "Lock Computer" to the Desktop Context Menu in Windows 7
    This will show you how to add or remove Lock Computer to the desktop context menu in Vista and Windows 7.
    EXAMPLE: Lock Computer in Desktop Context Menu
    Here's How:
    1. To Add "Lock Computer" to the Desktop Context Menu
    Add_Lock_Computer_to_Desktop_Context_Menu.reg
    B) Go to step 3.
    2. To Remove "Lock Computer" from the Desktop Context Menu
    Remove_Lock_Computer_from_Desktop_Context_Menu.reg
    3. Click on Save, and save the REG file to the desktop.
    4. Double click on the REG file to merge it, and click on Run, Yes (UAC-Windows 7) or Continue (UAC-Vista), Yes, and OK when prompted to approve the merge.
    5. When done, you can delete the downloaded .reg file if you like.
    6. Right click on your desktop to see the change.
  1. Posts : 8,679
    Excellent !
  2. Posts : 7
    Min XP Pro and Win 7 Pro
    I am running Win 7 pro and the "Lock" option is under "Shut Down" -> Lock. Will this reg edit work for this as well?
  3. Posts : 72,051
    Hello Dan,
    This tutorial will only add "Lock Computer" to your desktop context menu that will lock your computer when used.
    It does the same thing as the Lock in the Start Menu, but it doesn't affect anything in your Start Menu power menu.
    Hope this helps, :)
