User Folders - Restore Default Location
Page 20 of 31 FirstFirst ... 10181920212230 ... LastLast
  1. Posts : 2
    Windows 8.1 x64
       #190
    THANK YOU, Brink!
    I ran through Option 2 a second time and the folders are correct now. Phew...!
    I got an error message when I shut down afterwards (something about not able to access memory or something - it flashed off too quickly), but I've shut down again, and didn't get it so I'm hoping it's alright.
    Thank you very much for your help - and for providing all the great and detailed information on your site and forum; it's really helped me out as I'm new to windows 8.
    Emma
  2. Posts : 72,055
       #191
    You're most welcome Emma. I'm happy to hear it's working fine now. :)
  3. Posts : 1
    Windows 8.1 pro
       #192
    Thankyou very much for this article! I skim read the article and didn't at first realise that there were two similar folders in regedit called "Shell Folders" and "User Shell Folders". I just edited the registry for Shell Folders manually, rebooted, but of course that didn't work. Then I reread and changed User Shell Folders too, signed in and out of Windows 8.1 and problem solved! Thanks!
  4. Posts : 1,486
    Windows 10 Pro
       #193
    ok im having an issue with CMD. when i type the final command into CMD, i get these errors:
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
    C:\Windows\system32>attrib +r -s -h "%Patrick%\Downloads" /S /D
    Path not found - C:\Windows\system32\%Patrick%
    C:\Windows\system32>attrib +r -s -h "%Patrick%\Videos" /S /D
    I Put those folders there. but in the registry, everything is correct.... Help?
    Attached Thumbnails Attached Thumbnails User Folders - Restore Default Location-capture.png
  5. Posts : 10,796
       #194
    Use the right commands!
    User Folders - Restore Default Location step 25
  6. Posts : 1,486
    Windows 10 Pro
       #195
    i copied and pasted. and the ones you posted still dont work. "path not found"
  7. Posts : 10,796
       #196
    Ylou are in User Folders - Restore Default Location step 25 isn't it? If so, do exactly what is written there. If error.... post output
  8. Posts : 1,486
    Windows 10 Pro
       #197
    yes. thats what im trying to do. im trying to do step 25 and i get that error posted before.
  9. Posts : 10,796
       #198
    Only errors I see is your post #196
    why did you copy/paste attrib +r -s -h "%Patrick%\Downloads" /S /D
    ??? It's nowhere in tutorial. It looks like you aren't doing step 25 at all
  10. Posts : 1,486
    Windows 10 Pro
       #199
    this is step 25:
    25. In the elevated command prompt, Copy and Paste the command below exactly as is for the user folder icon that you want to restore to default, and press Enter. (see table below)
    NOTE: This will set the user folder attributes back to default. You can Copy and Paste these to make it easier for you.
    Windows 8 will not have the "My" in front of the user folder name anymore.
    User Folder	Command
    Contacts	 attrib +r -s -h "%USERPROFILE%\Contacts" /S /D
    Desktop	 attrib +r -s -h "%USERPROFILE%\Desktop" /S /D
    My Documents	 attrib +r -s -h "%USERPROFILE%\Documents" /S /D
    Downloads	 attrib +r -s -h "%USERPROFILE%\Downloads" /S /D
    Favorites	 attrib +r -s -h "%USERPROFILE%\Favorites" /S /D
    Links	 attrib +r -s -h "%USERPROFILE%\Links" /S /D
    My Music	 attrib +r -s -h "%USERPROFILE%\Music" /S /D
    My Pictures	 attrib +r -s -h "%USERPROFILE%\Pictures" /S /D
    Saved Games	 attrib +r -s -h "%USERPROFILE%\Saved Games" /S /D
    Screenshots (Windows 8/8.1)	 attrib +r -s -h "%USERPROFILE%\Pictures\Screenshots" /S /D
    Searches	 attrib +r -s -h "%USERPROFILE%\Searches" /S /D
    SkyDrive (Windows 8.1)	 attrib +r -s -h "%USERPROFILE%\SkyDrive" /S /D
    My Videos	 attrib +r -s -h "%USERPROFILE%\Videos" /S /D
    26. Close the elevated command prompt.
    EDIT:
    nvm i understand now. i thought i had to replace %USERPROFILE% with my user profile. so now we shall see how long it takes to come up...
