User Folders - Restore Default Location
Page 6 of 31 FirstFirst ... 4567816 ... LastLast
  1. Posts : 72,058
       #50
    This may help:
    • Backup anything that you do not want to lose in the Music folder to another location to be safe.
    • Delete the misnamed Music folder, and any other instance of it.
    • Using all of OPTION TWO in the tutorial, verify that the Music folder has the correct default name and path in both registry locations. If it doesn't, then change it so that it is.
    • If you Music folder is restored, then copy your files back.
  2. Posts : 89
    Win7 Pro x64
       #51
    OK, will try it, though I might have to wait to do so. "Life" is happening in the middle of my computer crisis. Darn life!!!
  3. Posts : 21
    Windows 7 Enterprise SP1 x64
       #52
    I have duplicate Desktop folders. I've followed the instructions in the OP several times to no avail.
    They are completely identical. Both have Location tabs and deleting one also deletes the other; recreating one recreates both. I'd prefer to leave them both deleted but then I'd get a "refers to location that is unavailable" error, and they reappear upon reboot.
    Any suggestions?
  4. Posts : 72,058
       #53
    Hello Caspid,
    Have you already tried OPTION TWO in the tutorial for the Desktop folder to see if that may be able to restore it?
  5. Posts : 21
       #54
    Yes, I'd tried that.
    I just noticed something though; entering shell:Personal opened up the Desktop instead of My Documents. I fixed My Documents using Option Two and one of the Desktop folders disappeared.
    Thanks for the help!
    By the way, do you know of a way to permanently delete or hide the Desktop, Favorites, and Searches folders from showing up in your user folder? I think this problem started with me trying to move Desktop into Documents.
  6. Posts : 72,058
       #55
    Caspid,
    Moving them to another location (ex: another partition or drive) instead will then have them not show up in the C:\Users\(user-name) folder location. They will now show up to where you moved them.
    User Folders - Change Default Location
  7. Posts : 1
    Please help!
    when i open the elevated command prompt, and put in the code thing for downloads it says-
    '0409' is not a recognized as an internal or external command, operable command or batch file.......
  8. Posts : 72,058
       #57
    Hello Coolcul, and welcome to Seven Forums.
    Is the Downloads folder at it's default location?
    Just to also be sure, did you right click on the command prompt shortcut and clicked on "Run as adiministrator" to open it first before copying and pasting the command in it? Double check for any typos in the command as well.
  9. Posts : 8
    win 7 pro x64
       #58
    hi, i have a problem with My Music folder deleted. i've downloaded and merged the reg file and now the regedit shows the correct default location C:Users\...\Music. but when typing in the command prompt i get an error
    File not found - C:Users\...\Music
    typing the my music shell command and nothing happens.
    i have rebooted several times and tried unsuccessfully to make the my music reappear.
    can i be advised in where i am going wrong please
  10. Posts : 72,058
       #59
    Hello rkidd, and welcome to Seven Forums.
    In addition to the download, did you also do steps 18-21 to change the location at the other registry entry?
