Product Key Number - Change
Page 2 of 2 FirstFirst 12
  1. Posts : 40
    Two soup cans and some string.
    Thanks for saving my @$$
    @Brink,
    This is TOTALLY WIZARD!
    I'm in the process of setting up two machines for a client of mine - both machines identical HP OEM Win7 Home Premium boxes, so I set one up soup-to-nuts and then cloned the one drive to the other box.
    It worked flawlessly. That is, until I remembered that this thing would probably barf on Genuine Windows, (or the first one would), which would have been a HUGE EMBARRASSMENT for me. . . So, I went to the computer's properties where I figured I'd just change the key - but there's no option there to do this. . . .
    If it weren't for your timely advice, I'd probably be so hozed it's not funny.
    Of course, I would not be surprised if the actual instal had a generic key that would work on a zillion identical boxes - but I'd rather not take that chance. Especially when the client is a lawyer!
    Thanks!
    Jim (JR)
  2. Posts : 72,052
    You're most welcome Jim. :)
    I don't blame you. Best to be safe than sued.
    If it was the OEM-SLP key number that was used to activate them, then it will work to activate all of the exact same model numbers of that brand since that is the volume number that the factory uses to activate them with. This key number is also the one that is used when doing a factory recovery. This key number is not the same as the one on the COA sticker.
    If it was the OEM-COA key number on the sticker, then yeah you would not have been able to activate with it on both computers. The OEM-COA key number is specific for activation of only the original computer.
  3. Posts : 1
    This worked except...
    You sed:
    slmgr.vbs -ipk
    slmgr.vbs -ato
    It returned some errors until I swapped the two hyphens with forward slashes, i.e., slmgr.vbs /ipk
  4. Posts : 72,052
    Hello uhClem, and welcome to Seven Forums.
    It should work with either - or /, but I changed it so others may not have the same issue you did. :)
  5. Posts : 2
    Windows 7 Home Premium 32 bit.
       #14
    IT'S WORK
