ROBOCOPY - Create Backup Script
Page 4 of 32 FirstFirst ... 2345614 ... LastLast
  1. Posts : 2,177
    Windows 8.1 Pro x64
       #30
    can you provide an example of the file paths with a description of what needs backing up and what doesnt?
    e.g.
    c:\projects\seven_forums\posts
    c:\projects\seven_forums\threads
    c:\projects\seven_forums\data
    c:\projects\seven_forums\admin
    c:\projects\seven_forums\stuff
    i would want folders posts, threads and data backed up.
    something along those lines so i can understand your requirements a little better.
    Cheers
  2. Posts : 5
    Windows 7 Pro
       #31
    Folder structure
    Below is a typical folder structure:
    (we have 100's of these with the difference being in the bldg# and Proj#)
    R:
    --Bldg# or ProjectType
    ----Project#1
    ------500_CAD
    --------3D
    --------A
    --------C
    --------D
    --------E
    --------G
    --------M
    --------S
    --------Archive
    --------xArchive
    --------xImage
    --------xInbox
    --------xIssue
    --------xOutbox
    --------xPlot
    --------xSupport
    (i.e., R:\234A\60101003\500_CAD\xInbox)
    The folders to be excluded are Archive, xArchive, xInbox, xSupport, xTemp
    Thanks, Ron
  3. Posts : 2,177
    Windows 8.1 Pro x64
       #32
    R:
    ----Project#1
    ------500_CAD
    --------3D
    --------A
    --------C
    --------D
    --------E
    --------G
    --------M
    --------S
    --------Archive
    --------xArchive
    --------xImage
    --------xInbox
    --------xIssue
    --------xOutbox
    --------xPlot
    --------xSupport
    Thanks, Ron
    Try the following:
    robocopy <source> <destination> /e /xd Archive xArchive xInbox xSupport xTemp
    /e = include all directories including subdirectories
    /xd - exclude directories <dir1> <dir2> <dir3> (this would exclude any folder with the stated names)
    the other option would be to use a wildcard, for example, if you wanted to exclude all folders starting with an x then the following would also work:
    robocopy <source> <destination> /e /xd x*
    Hope this helps?
    Regards,
    JDobbsy1987
  4. Posts : 5
    Windows 7 Pro
       #33
    I am already using code as you showed, including the * in the excluded folder list.
    But, per an earlier post (my apologies as I thought I was still in my earlier thread), Golden replied "Robocopy treats the * as part of the name, and of course Windows does not allow a folder to contain a * in its name."
    But if my excluded folders list includes "Archive", will it exclude every folder that is named "Archive"?
    Thanks much, Ron
  5. Posts : 2,177
    Windows 8.1 Pro x64
       #34
    I have just tested the following script and it worked fine:
    It copied all folders but not any folders starting with an X
    Correct... unless you explicitly specified the file path/folder e.g.
    robocopy <source> <destination> /e /xd "R:\234A\60101003\500_CAD\xInbox"
    Do you have a lot of folders with the same name where some you would want to back up and others you wouldn't?
  6. Posts : 1,797
    Win 7 Ultimate, Win 8.1 Pro, Linux Mint 19 Cinnamon (All 64-Bit)
       #35
    Hello all,
    I would like to copy all the files from my T:\Data Backup drive to my D:\Data drive (I'm going to be wiping everything off D: and restoring all the files from my T: drive).
    I'm wanting to copy everything, all subfolders, files, dates, times, attributes and security permissions. And using 12 threads as I am copying about 540gb of data.
    Would this command do the job?
    robocopy T:\ D:\ /COPY:DATSOU /MT:12 /e /np /log+:backup_log.txt
    Any help would be appreciated. :)
  7. Posts : 2,177
    Windows 8.1 Pro x64
       #36
    Burdus32 said:
    Hello all,
    I don't see why that wouldn't work but me personally would remove the /np so i can see the progress it is making plus i would put some retry option in just encase there was an issue accessing the destination drive during the copy:
    e.g.
    /Z /R:10 /W:20
    this way the copy shouldn't fail but wait 20 seconds and try again (the retry enables it to carry on from where it stopped rather than starting it all over again.)
    Regards,
    JDobbsy1987
  8. Posts : 1,797
       #37
    Thanks JDobbsy,
    so would this command be ok?
    robocopy <source> <destination> /E /Z /COPYALL /MT:12 /log+:backup_log.txt /R:10 /W:20
  9. Posts : 2,177
    Windows 8.1 Pro x64
       #38
    Burdus32 said:
    Thanks JDobbsy,
    That looks like it will do a good job
    As a precautionary... I would always do a quick test on some MOC up folders/files
    Regards,
    JDobbsy1987
  10. Posts : 1,797
       #39
    Brilliant, thanks for the help JDobbsy!
    Just one quick question, is the
    /COPYALL
    command the same as
    /COPY: DATSOU
    I have an old backup drive that I use for testing, I'll try it out on that first. :)
