#50
Great stuff Burdus - there is real wealth of knowledge accumulated here.
If only you had written this article a year and a half ago. :-P
Great work Golden.
For years I've used an xcopy replacement utility called xxcopy and it functions a lot like Robocopy. It's /clone switch is a lot like Robocopy's /MIR switch.
One thing it does that, as far as I can tell, Robocopy can't, is create destination folder names based on the date. For instance, tonight's incremental backup would be in a folder called 2012-03-29.
With Robocopy in a batch file I've been deleting folders named for the weekday and having them recreated in the destination when Robocopy runs. As in...
:mon
rmdir x:\backup\Daily\1-Monday\ /S /Q
robocopy d:\shared x:\backup\Daily\1-Monday [long list of switches]
The batch file starts by testing for the day of the week and then skips to the part of the batch file for that day (as in :mon). I end up with 7 backup folders only containing files that had the archive bit set for that given day.
But I only get seven days, unless I can figure out how to get the task manager to run two batch files on alternating weeks.
Any ideas on how to get incremental backups that go back further than one week?
Hi Golden,
I Need your help with robocopy script.
I have extenal IP hard drive 2 TB each and 4 of them. I want to write a script so It will check if Hardrive is live and copy the data over there. When its copy new data I want to create a new folder with current date like " Backup 12-04-25"
So far this is what i can do in my test.
robocopy "C:\SQL" C:\Backup\ /copyAT /e /z /v /tee /log:c:backup_log.txt
pause
Can you help?
Thanks,
Arpit
Hi All,
I have written a robocopy script to migrate the company I work for from XP to 7 64bit and to do transfers from 7 to 7 for future data back up and restore after reimaging machines.
Like most scripts you can only look at it so long before it starts to run together. Would it be ok to post it here to get another set of eyes on it? It works really well but I just want to make sure I have not left something out or have to much in terms of the switches.
Great!
Let me explain a bit what I have it doing first then I'll put it in the next post.
I made it to be an interactive "program" for lack of a better term.
I have distributed it out to my 16 co-workers in 8 different sites around the country as we have have the task of moving 5000 users to Windows 7.
It is launched from a folder containing the .cmd file and robocopy.exe (for portability).
The script opens a command prompt window where you make a task selection. 1-7, 0 to exit.
The options1-2 are direct machine to machine data transfers over the LAN. XP to 7 & 7 to 7.
The options 3-4 are for hard drive pulls from the old machine using a powered USB drive adaptor for data transfer to the new machine.
The options 5-6 are to copy the data to an extrenal USB storage device.
Option 7 restores it from the USB drive.
In it you will see that I have per-converted all XP folders/locations to Windows 7 folder/locations for easier restore.
So to launch it, you just double click the cmd file in a folder with the robocopy.exe in it (for XP).
You then get a prompt asking for UserID, Old computer name, drive letter, depending on the selection.
After that you'll get the idea what happens.
Script in the next post.
As you can see we target specific data, makes for a better user experience.Code:@ECHO OFF c:\windows\system32\cmd.exe /c mode con cols=100 lines=45 Color 3F CLS :MENU ECHO.________________________________________________________________________________ ECHO. ECHO. Windows 7 Migration Tool ECHO. ECHO. Note: All data copies from Windows XP are translated into the Windows 7 ECHO. directory structure. ("Documents and Settings" to "Users", etc.) ECHO. ECHO. !!!Remember to turn off UAC and set power option to never sleep!!! ECHO.________________________________________________________________________________ ECHO. ECHO ............................................................ ECHO PRESS 1 2 3 4 5 6 7 to select your task, or 0 to EXIT. ECHO ............................................................ ECHO. ECHO 1 - Network Data Transfer: Old XP (remote) to new Windows 7 (local) ECHO. ECHO 2 - Network Data Transfer: Old 7 (remote) to new Windows 7 (local) ECHO. ECHO 3 - Local USB Drive Adaptor XP drive to 7 (C:) (local) ECHO. ECHO 4 - Local USB Drive Adaptor 7 drive to 7 (C:) (local) ECHO. ECHO 5 - Local USB Data Backup: Local XP (C:) to local USB drive ECHO. ECHO 6 - Local USB Data Backup: Local 7 (C:) to local USB drive ECHO. ECHO 7 - USB Drive Restore: Restore local USB drive to new Windows 7 (local) ECHO. ECHO 0 - EXIT ECHO. SET /P M=Type 1, 2, 3, 4, 5, 6, 7, or 0, then press ENTER: IF %M%==1 GOTO XPto7 IF %M%==2 GOTO 7to7 IF %M%==3 GOTO XPUSBtoC IF %M%==4 GOTO 7USBtoC IF %M%==5 GOTO XPCtoE IF %M%==6 GOTO 7CtoE IF %M%==7 GOTO ResEtoC7 IF %M%==0 GOTO Quit rem ------------------------------------------------------------------------ :XPto7 ECHO. ECHO.[-----Network Data Transfer: Old XP to New 7-----] ECHO. NET USE Z: /Delete > NUL ECHO Enter Users OracleID: Set /p USER= REM OracleID is equivelent to AD User ID ECHO. ECHO Network Share: Enter the user's old XP Computer Name: Set /P OldXP= NET USE Z: \\%OldXP%\C$ REM robocopy Z:\ C:\ /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "autoexec.bat" "boot.ini" "cmldr" "config.sys" "Desktop.ini" "hiberfil.sys" "IO.SYS" "NTDETECT.COM" "ntldr" "MSDOS.SYS" "pagefile.sys" "Thumbs.db" /XD ".Xilinx" "Applications" "Cadence" "CadenceHome" "cmdcons" "Config.msi" "Dell" "Documents and Settings" "Drivers" "i386" "Intel" "MSOCache" "Notes" "Program Files" "RECYCLER" "$Recycle.Bin" "SP3" "System Volume Information" "swshare" "swtools" "valueadd" "WINDOWS" "Xilinx" /L /LOG+:Step1.txt robocopy Z:\Notes "C:\Program Files (x86)\Lotus\Notes" notes.ini /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy Z:\Notes\Data "C:\Program Files (x86)\Lotus\Notes\Data" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Desktop" C:\Users\%USER%\Desktop /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Favorites" C:\Users\%USER%\Favorites /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\My Documents" C:\Users\%USER%\Documents /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /XD "Downloads" "Favorites" "Pictures" "My Pictures" "Music" "My Music" "Shapes" "My Shapes" "Videos" "My Videos" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\My Documents\Favorites" C:\Users\%USER%\Favorites /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\My Documents\My Music" C:\Users\%USER%\Music /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\My Documents\Downloads" C:\Users\%USER%\Downloads /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\My Documents\My Pictures" C:\Users\%USER%\Pictures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\My Documents\My Videos" C:\Users\%USER%\Videos /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\My Documents\My Shapes" "C:\Users\%USER%\Documents\My Shapes" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Local Settings\Application Data\Microsoft\Outlook" "C:\Users\%USER%\Documents\Outlook Files" *.pst /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Application Data\Microsoft\Signatures" C:\Users\%USER%\AppData\Roaming\Microsoft\Signatures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Application Data\Microsoft\Stationery" "C:\Program Files (x86)\Common Files\Microsoft Shared\Stationery" /E /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Application Data\Microsoft\Templates" C:\Users\%USER%\AppData\Roaming\Microsoft\Templates /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Application Data\Microsoft\Proof" C:\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Application Data\Microsoft\UProof" C:\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Application Data\Microsoft\Outlook" C:\Users\%USER%\AppData\Roaming\Microsoft\Outlook *.nk2 /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Documents and Settings\%USER%\Local Settings\Application Data\Microsoft\Outlook" C:\Users\%user%\AppData\Local\Microsoft\Outlook *.pab *.oab /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt NET USE Z: /Delete > NUL GOTO END rem ------------------------------------------------------------------------ :7to7 ECHO. ECHO.[------Network Data Transfer: Old 7 to New 7------] ECHO. NET USE Z: /Delete > NUL ECHO Enter Users OracleID: Set /p USER= REM OracleID is equivelent to AD User ID ECHO. ECHO Network Share: Enter the user's old 7 Computer Name: Set /P Old7= NET USE Z: \\%Old7%\C$ REM robocopy Z:\ C:\ /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /XF "*.log" "Thumbs.db" "Desktop.ini" ".rnd" "bootmgr" "hiberfil.sys" "pagefile.sys" /XD ".Xilinx" "Applications" "Boot" "Cadence" "CadenceHome" "Config.msi" "de8b2a33417deb7cb2a115cae06cd1" "Dell" "Documents and Settings" "Drivers" "Intel" "Kontiki" "MSOCache" "PerfLogs" "Program Files" "Program Files (x86)" "ProgramData" "Recovery" "$Recycle.Bin" "RECYCLER" "System Volume Information" "USERS" "WINDOWS" "Xilinx" /L /LOG+:Step1.txt robocopy "Z:\Program Files (x86)\Lotus\Notes" "C:\Program Files (x86)\Lotus\Notes" notes.ini /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Program Files (x86)\Lotus\Notes\Data" "C:\Program Files (x86)\Lotus\Notes\Data" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "Z:\Program Files (x86)\Common Files\Microsoft Shared\Stationery" "C:\Program Files (x86)\Common Files\Microsoft Shared\Stationery" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy Z:\Users\%USER% C:\Users\%USER% /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "Album*.jpg" "*.log" *.policy" "Thumbs.db" "Desktop.ini" "ntuser*.*" /XD "AppData" "Application Data" "Local Settings" "Office Genuine Advantage" /L /LOG+:Step1.txt robocopy Z:\Users\%USER%\Documents C:\Users\%USER%\Documents /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "Album*.jpg" "*.log" *.policy" "Thumbs.db" "Desktop.ini" "ntuser*.*" /XD "AppData" "Application Data" "Local Settings" "Office Genuine Advantage" /L /LOG+:Step1.txt robocopy Z:\Users\%USER%\AppData\Roaming\Microsoft\Signatures C:\Users\%USER%\AppData\Roaming\Microsoft\Signatures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy Z:\Users\%USER%\AppData\Roaming\Microsoft\Templates C:\Users\%USER%\AppData\Roaming\Microsoft\Templates /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy Z:\Users\%USER%\AppData\Roaming\Microsoft\UProof C:\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy Z:\Users\%USER%\AppData\Roaming\Microsoft\Outlook C:\Users\%USER%\AppData\Roaming\Microsoft\Outlook *.nk2 /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy Z:\Users\%user%\AppData\Local\Microsoft\Outlook C:\Users\%user%\AppData\Local\Microsoft\Outlook *.pab *.oab /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt NET USE Z: /Delete > NUL GOTO END rem ------------------------------------------------------------------------ :XPUSBtoC ECHO. ECHO.[----------Pulled Drive on USB Drive Adapter XP Data Transfer to 7-----------] ECHO. ECHO Enter Users OracleID: Set /p USER= REM OracleID is equivelent to AD User ID ECHO. ECHO Enter the USB drive letter: (example) X: Set /p USBDrive= REM robocopy %USBDrive% C:\ /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "autoexec.bat" "boot.ini" "cmldr" "config.sys" "Desktop.ini" "hiberfil.sys" "IO.SYS" "NTDETECT.COM" "ntldr" "MSDOS.SYS" "pagefile.sys" "Thumbs.db" /XD ".Xilinx" "Applications" "Cadence" "CadenceHome" "cmdcons" "Config.msi" "Dell" "Documents and Settings" "Drivers" "i386" "Intel" "MSOCache" "Notes" "Program Files" "RECYCLER" "$Recycle.Bin" "SP3" "System Volume Information" "swshare" "swtools" "valueadd" "WINDOWS" "Xilinx" /L /LOG+:Step1.txt robocopy %USBDrive%\Note "C:\Program Files (x86)\Lotus\Notes" notes.ini /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy %USBDrive%\Notes\Data "C:\Program Files (x86)\Lotus\Notes\Data" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Desktop" C:\Users\%USER%\Desktop /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Favorites" C:\Users\%USER%\Favorites /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\My Documents" C:\Users\%USER%\Documents /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /XD "Downloads" "Favorites" "Pictures" "My Pictures" "Music" "My Music" "Shapes" "My Shapes" "Videos" "My Videos" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\My Documents\Favorites" C:\Users\%USER%\Favorites /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\My Documents\My Music" C:\Users\%USER%\Music /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\My Documents\Downloads" C:\Users\%USER%\Downloads /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\My Documents\My Pictures" C:\Users\%USER%\Pictures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\My Documents\My Videos" C:\Users\%USER%\Videos /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\My Documents\My Shapes" "C:\Users\%USER%\Documents\My Shapes" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Local Settings\Application Data\Microsoft\Outlook" "C:\Users\%USER%\Documents\Outlook Files" *.pst /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Application Data\Microsoft\Signatures" C:\Users\%USER%\AppData\Roaming\Microsoft\Signatures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Application Data\Microsoft\Stationery" "C:\Program Files (x86)\Common Files\Microsoft Shared\Stationery" /E /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Application Data\Microsoft\Templates" C:\Users\%USER%\AppData\Roaming\Microsoft\Templates /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Application Data\Microsoft\Proof" C:\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Application Data\Microsoft\UProof" C:\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Application Data\Microsoft\Outlook" C:\Users\%USER%\AppData\Roaming\Microsoft\Outlook *.nk2 /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Documents and Settings\%USER%\Local Settings\Application Data\Microsoft\Outlook" C:\Users\%user%\AppData\Local\Microsoft\Outlook *.pab *.oab /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt GOTO END rem ------------------------------------------------------------------------ :7USBtoC ECHO. ECHO.[----------Pulled Drive on USB Drive Adapter 7 Data Transfer to 7-----------] ECHO. ECHO Enter Users OracleID: Set /p USER= REM OracleID is equivelent to AD User ID ECHO. ECHO Enter the USB drive letter: (example) X: Set /p USBDrive= REM robocopy %USBDrive% C:\ /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /XF "*.log" "Thumbs.db" "Desktop.ini" ".rnd" "bootmgr" "hiberfil.sys" "pagefile.sys" /XD ".Xilinx" "Applications" "Boot" "Cadence" "CadenceHome" "Config.msi" "de8b2a33417deb7cb2a115cae06cd1" "Dell" "Documents and Settings" "Drivers" "Intel" "Kontiki" "MSOCache" "PerfLogs" "Program Files" "Program Files (x86)" "ProgramData" "Recovery" "$Recycle.Bin" "RECYCLER" "System Volume Information" "USERS" "WINDOWS" "Xilinx" /L /LOG+:Step1.txt robocopy "%USBDrive%\Program Files (x86)\Lotus\Notes" "C:\Program Files (x86)\Lotus\Notes" notes.ini /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Program Files (x86)\Lotus\Notes\Data" "C:\Program Files (x86)\Lotus\Notes\Data" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "%USBDrive%\Program Files (x86)\Common Files\Microsoft Shared\Stationery" "C:\Program Files (x86)\Common Files\Microsoft Shared\Stationery" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy %USBDrive%\Users\%USER% C:\Users\%USER% /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "Album*.jpg" "*.log" *.policy" "Thumbs.db" "Desktop.ini" "ntuser*.*" /XD "AppData" "Application Data" "Local Settings" "Office Genuine Advantage" /L /LOG+:Step1.txt robocopy %USBDrive%\Users\%USER%\Documents C:\Users\%USER%\Documents /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "Album*.jpg" "*.log" *.policy" "Thumbs.db" "Desktop.ini" "ntuser*.*" /XD "AppData" "Application Data" "Local Settings" "Office Genuine Advantage" /L /LOG+:Step1.txt robocopy %USBDrive%\Users\%USER%\AppData\Roaming\Microsoft\Signatures C:\Users\%USER%\AppData\Roaming\Microsoft\Signatures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy %USBDrive%\Users\%USER%\AppData\Roaming\Microsoft\Templates C:\Users\%USER%\AppData\Roaming\Microsoft\Templates /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy %USBDrive%\Users\%USER%\AppData\Roaming\Microsoft\UProof C:\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy %USBDrive%\Users\%USER%\AppData\Roaming\Microsoft\Outlook C:\Users\%USER%\AppData\Roaming\Microsoft\Outlook *.nk2 /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy %USBDrive%\Users\%user%\AppData\Local\Microsoft\Outlook C:\Users\%user%\AppData\Local\Microsoft\Outlook *.pab *.oab /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt GOTO END rem ------------------------------------------------------------------------ :XPCtoE ECHO. ECHO.[-----------Old XP Machine Drive to USB Drive Backup-----------] ECHO. ECHO Enter Users OracleID: Set /p USER= REM OracleID is equivelent to AD User ID ECHO. ECHO Enter the USB drive letter: (example) X: Set /p USBDrive= MD %USBDrive%\%USER% REM robocopy C:\ %USBDrive%\%USER%\ /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "autoexec.bat" "boot.ini" "cmldr" "config.sys" "Desktop.ini" "hiberfil.sys" "IO.SYS" "NTDETECT.COM" "ntldr" "MSDOS.SYS" "pagefile.sys" "Thumbs.db" /XD ".Xilinx" "Applications" "Cadence" "CadenceHome" "cmdcons" "Config.msi" "Dell" "Documents and Settings" "Drivers" "i386" "Intel" "MSOCache" "Notes" "Program Files" "RECYCLER" "$Recycle.Bin" "SP3" "System Volume Information" "swshare" "swtools" "valueadd" "WINDOWS" "Xilinx" /L /LOG+:Step1.txt robocopy C:\Notes "%USBDrive%\%USER%\Program Files (x86)\Lotus\Notes" notes.ini /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy C:\Notes\Data "%USBDrive%\%USER%\Program Files (x86)\Lotus\Notes\Data" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Desktop" %USBDrive%\%USER%\Users\%USER%\Desktop /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Favorites" %USBDrive%\%USER%\Users\%USER%\Favorites /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\My Documents" %USBDrive%\%USER%\Users\%USER%\Documents /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /XD "Downloads" "Favorites" "Pictures" "My Pictures" "Music" "My Music" "Shapes" "My Shapes" "Videos" "My Videos" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\My Documents\Favorites" %USBDrive%\%USER%\Users\%USER%\Favorites /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\My Documents\My Music" %USBDrive%\%USER%\Users\%USER%\Music /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\My Documents\My Pictures" %USBDrive%\%USER%\Users\%USER%\Pictures /E /COPYALL /B /SEC /MIR /V /NP /R:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /W:2 /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\My Documents\My Videos" %USBDrive%\%USER%\Users\%USER%\Videos /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\My Documents\My Shapes" "%USBDrive%\%USER%\Users\%USER%\Documents\My Shapes" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\My Documents\Downloads" %USBDrive%\%USER%\Users\%USER%\Downloads /E /COPY:DATSO /V /NP /R:2 /W:2 /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Local Settings\Application Data\Microsoft\Outlook" "%USBDrive%\%USER%\Users\%USER%\Documents\Outlook Files" *.pst /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Application Data\Microsoft\Signatures" %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\Signatures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Application Data\Microsoft\Stationery" "%USBDrive%\%USER%\Program Files (x86)\Common Files\Microsoft Shared\Stationery" /E /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Application Data\Microsoft\Templates" %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\Templates /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Application Data\Microsoft\Proof" %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Application Data\Microsoft\UProof" %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Application Data\Microsoft\Outlook" %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\Outlook *.nk2 /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Documents and Settings\%USER%\Local Settings\Application Data\Microsoft\Outlook" %USBDrive%\%USER%\Users\%USER%\AppData\Local\Microsoft\Outlook *.pab *.oab /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt attrib -h -s %USBDrive%\%USER% GOTO END rem ------------------------------------------------------------------------ :7CtoE ECHO. ECHO.[------------Old 7 Machine Drive to USB Drive Backup------------] ECHO. ECHO Enter Users OracleID: Set /p USER= REM OracleID is equivelent to AD User ID ECHO. ECHO Enter the USB drive letter: (example) X: Set /p USBDrive= MD %USBDrive%\%USER% REM robocopy C:\ %USBDrive%\%USER%\ /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" ".rnd" "bootmgr" "hiberfil.sys" "pagefile.sys" /XD ".Xilinx" "Applications" "Boot" "Cadence" "CadenceHome" "Config.msi" "de8b2a33417deb7cb2a115cae06cd1" "Dell" "Documents and Settings" "Drivers" "Intel" "Kontiki" "MSOCache" "PerfLogs" "Program Files" "Program Files (x86)" "ProgramData" "Recovery" "$Recycle.Bin" "RECYCLER" "System Volume Information" "USERS" "WINDOWS" "Xilinx" /L /LOG+:Step1.txt robocopy "C:\Program Files (x86)\Lotus\Notes" "%USBDrive%\%USER%\Program Files (x86)\Lotus\Notes" notes.ini /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Program Files (x86)\Lotus\Notes\Data" "%USBDrive%\%USER%\Program Files (x86)\Lotus\Notes\Data" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy "C:\Program Files (x86)\Common Files\Microsoft Shared\Stationery" "%USBDrive%\%USER%\Program Files (x86)\Common Files\Microsoft Shared\Stationery" /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy C:\Users\%USER% %USBDrive%\%USER%\Users\%USER% /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "Album*.jpg" "*.log" "*.policy" "Thumbs.db" "Desktop.ini" "ntuser*.*" /XD "AppData" "Application Data" "Local Settings" "Office Genuine Advantage" /L /LOG+:Step1.txt robocopy C:\Users\%USER%\Documents %USBDrive%\%USER%\Users\%USER%\Documents /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "Album*.jpg" "*.log" "*.policy" "Thumbs.db" "Desktop.ini" "ntuser*.*" /XD "AppData" "Application Data" "Local Settings" "Office Genuine Advantage" /L /LOG+:Step1.txt robocopy C:\Users\%USER%\AppData\Roaming\Microsoft\Signatures %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\Signatures /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy C:\Users\%USER%\AppData\Roaming\Microsoft\Templates %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\Templates /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy C:\Users\%USER%\AppData\Roaming\Microsoft\UProof %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\UProof /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy C:\Users\%USER%\AppData\Roaming\Microsoft\Outlook %USBDrive%\%USER%\Users\%USER%\AppData\Roaming\Microsoft\Outlook *.nk2 /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt robocopy C:\Users\%USER%\AppData\Local\Microsoft\Outlook %USBDrive%\%USER%\Users\%USER%\AppData\Local\Microsoft\Outlook *.pab *.oab /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "Thumbs.db" "Desktop.ini" /L /LOG+:Step1.txt attrib -h -s %USBDrive%\%USER% GOTO END rem ------------------------------------------------------------------------ :ResEtoC7 ECHO. ECHO.[------------Local USB Drive 7 Data Restore------------] ECHO. ECHO Enter Users OracleID: Set /p USER= REM OracleID is equivelent to AD User ID ECHO. ECHO Enter the USB drive letter: (example) X: Set /p USBDrive= ECHO. robocopy %USBDrive%\%USER%\ C:\ /E /COPY:DATSO /V /NP /R:2 /W:2 /XA:SHO /XF "*.log" "$Recycle.Bin" "Thumbs.db" "Desktop.ini" /XD "$Recycle.Bin" /L /LOG+:Step1.txt GOTO END :QUIT ECHO.________________________________________________________________________________ ECHO. ECHO. ECHO. Terminated process, no action taken. ECHO. ECHO. ECHO.________________________________________________________________________________ :END ECHO.________________________________________________________________________________ ECHO. ECHO. Completed! check the log files below for results... ECHO. ECHO.________________________________________________________________________________ ECHO. dir step*.txt /b ECHO. Pause
You will also see a couple what appeears to be duplicate lines, this because you can not trust users to put things where they go, you know what I am talking about.
