ROBOCOPY - Create Backup Script
Page 14 of 32 FirstFirst ... 4121314151624 ... LastLast
  1. Posts : 19,383
       #130
    This might be a permissions issue. Please try the following:
    robocopy "C:\Users\VocWorks User" E:\Backup /MIR /E /COPYALL
    I just noticed that /mir also implies /e - I think that must have changed recently, or perhaps I missed it, so yes, you could disregard the /e, but only if you are using /mir.
    Regards,
    Golden
  2. Posts : 2
    Windows 7 64bit
       #131
    I did the about as suggest. I even took the /E out. I am getting an error. Screen shot attached.
    Attached Thumbnails Attached Thumbnails ROBOCOPY - Create Backup Script-error.jpg
  3. Posts : 4
    Windows 7 x64
       #132
    I support the mention about permissions. Windows 7 is quite problematic if you don't know how to handle it properly.
    So try to run robocopy as an administrator (even when you already are). If you're using the cmd.exe to run robocopy do this: Start / type: cmd in the search field / right click on the cmd icon / click on 'run as administrator'
    Then you paste or type: robocopy "C:\Users\VocWorks User" E:\Backup /MIR
    Alternatively, you can exclude problematic files adding this switch at the end: /xf "C:\Users\VocWorks User/NTUSER.DAT".
  4. Posts : 5
    Windows 7 Home Premium 32 bit
       #133
    Don't understand why, but it works.....
    I'm sort of new to RoboCopy and I have become very impressed with what it can do. I played around with the following problem until I got it resolved, but I don't understand why it works.
    This is part of the directory structure on my 'c' drive:
    If I use this command:
    robocopy "c:\users\Barry\My Documents" "g:\users\Barry\My Documents" /e /mt:4 /tee /w:2 /xj
    It appears that the command works just fine, BUT the 'My Documents' folder doesn't get created on the 'g' drive.
    However, if I use this command:
    robocopy "c:\users\Barry\Documents" "g:\users\Barry\Documents" /e /mt:4 /tee /w:2 /xj
    The 'My Documents' folder DOES get created and the folders/files get created/copied to 'g'.
    Why does this work???
  5. Posts : 5
       #134
    This is what I see when I open Explorer:
    Thanks for any knowledge sharing......
  6. Posts : 19,383
       #135
    Hi Epoc,
    My Documents is one of those mystical junction points in Windows Explorer - its real name isn't 'My Documents', its actually just 'Documents', which is why your second version works just fine.
    See below (notice the name in the bar at the top of the image).
    Attached Thumbnails Attached Thumbnails ROBOCOPY - Create Backup Script-capture.png
  7. Posts : 5
       #136
    Windows, what would we do without it.......
    Thank you for the reply. (Your tutorial is actually what got me started using RoboCopy)
  8. Posts : 19,383
       #137
  9. Posts : 14,606
       #138
    thought i would point out colin that the font color in the first two steps of the tutorial makes it unviewable with the sf black theme, try it and see what i mean.
    i can see it by highlighting the area
  10. Posts : 19,383
       #139
    Cheers Julian - I never noticed that before, but looking closer Step 1 and 2 are black, and the rest is the default? colour, whatever it is - it doesn't show in the box. I'll find out what it is and fix it.
    EDIT: Fixed!
