#140
How to use ROBOCOPY AFTER manually backing up
Hello,
Great thread on robocopy.
I have a NAS and manually copied over the files. I now want to use robocopy.
I am wary of using robocopy as my backup tool as I have some thoughts which may cause issues:
1) The datetime on the folders and files on the NAS are when I did the manual copy, not the source attributes, and so if I use the robocopy /MIR I am not sure what will happen.
How should I sync the NAS folder/files attributes back to the source with robocopy so I can use /MIR successfully?
Basically asking what should be the steps if a person used to copy folders manually and NOW wants to use robocopy? You guide seems to be for first time use and some points on how to transition from a manual process would be great.
2) Also, I have a number of source folders from many machines which I copy to ONE folder on the NAS. That is, all sub folders from multiple sources go to ONE folder on the NAS, which essentially is all the source sub folders under one folder on the NAS.
I want to be able to mirror the source locations to a "merged" single destination folder and only copy over changes.
Is that possible with robocopy?
Thanks!
