ROBOCOPY - Create Backup Script
Page 17 of 32 FirstFirst ... 7151617181927 ... LastLast
  1. Posts : 26
    Windows 10 Home, 64-bit
       #160
    Locks on your front door can be a pain, too, especially when you have an armload of groceries. But, removing them entails risk.
    Once you learn to manage UAC, it's really not a big deal unless you're constantly installing and uninstalling software.
  2. Posts : 1
    Windows 7 pro x64
       #161
    Thanks for this post Golden!!!
    Great post and very useful!!! We need more post like this especially a template for daily, weekly Robocopy backup!!!
  3. Posts : 12
    Windows 7 Enterprise x64
       #162
    acornada said:
    I'm well aware that /MIR = /PURGE + /E. That will never delete files from source.
    Microsoft Technet said:
    /PURGE : Deletes destination files and directories that no longer exist in the source.
    That means that Robocopy will delete files from destination, if you have deleted them from source.
    Neither /PURGE nor /MIR will delete files from source. Please test it, you'll see.
    I will NEVER use /MIR in a backup script. If I accidentally delete something but don't notice it, then run my script, where is the file/folder? Nowhere. Poof! Gone! I may not realize the problem for months.
    In fact, this exact scenario came up at work just a couple weeks ago. A co-worker had written a robocopy script for a remote file share to backup one USB drive to another. Part of this script was /mir, /mon:1 and /mot:15. Thank whoever that the script wasn't running when I was emailed asking to restore an entire project folder with 3GB 's of data that was accidentally deleted.
    People don't seem to realize we're not only backing up in case a drive fails, but also in case someone's brain fails. :)
  4. Posts : 26
       #163
    You miss the point. The tutorial says that MIR will delete files from source, which is not true. Neither /PURGE nor /MIR will delete files from source.
    As for your situation, yes, what you want is a backup, not a mirroring. Mirroring is a very useful backup technique, but it doesn't replace having archived backups (which is what you want). A mirrored drive or directory ensures that if the source is damaged or fails, you can begin working again from the mirror which is very recent or even real time. Mirroring and point-in-time or archived backups are different techniques, both useful, for different needs.
    You still need archived backups, which are backups of files as at a particular point in time. That way, when you realize that you deleted something last week that you now need, you can restore from a two-week-old backup.
    But, the tutorial is clearly wrong. Neither /PURGE nor /MIR will delete files from source. Never.
  5. Posts : 12
       #164
    I didn't miss the point. I was round-a-boutly agreeing with you. My point was if /mir is used in a backup scheme, and I accidentally delete something from the source, then run the script, I'm screwed.
  6. Posts : 26
       #165
    Yep, that would be true. You don't want mirroring, at least not frequent mirroring. I use a combination of archived backups and a mirrored backup. Both are useful, for different goals.
  7. Posts : 3
    Hello, I cannot get this script to work???CMD prompts and just keeps running this data over and over? please help
    robocopy E:\Data1 G:\Backups\Data1 robocopy F:\Data2 G:\Backups\Data2 robocopy F:\Data3 Q:\Backups\Data3 pause
  8. Posts : 3
    Nice tutorial I will definitely use this!!!
  9. Posts : 26
       #168
    1. That won't work, AFAIK, you can't just string together separate commands/tasks and enter them all as a single line into CMD.
    2. If you want to have all three of those tasks run, do it in a batch file, where each is on a separate line.
  10. Posts : 19,383
       #169
    Welcome to SevenForums,
    Try this:
    pause
    Regards,
    Golden
