#200
I'll have a look around and see what I can find. Thanks.
Yeah, but I'm not willing to pay for macrium and the free version doesn't let you exclude folders or backup certain folders.
Dear Experts,
I have robocopy running continuously to mirror a folder every X hours. The windows 2008R2 server running the code is set to start the script at startup. Everything appears to be working fine, except the log files are becoming to be gigs big (too big to open with notepad, etc). I can manually stop the process, rename the log file, then the restart the process, but I am looking for a way to programmatically limit the size of the log file. Is this possible? Thanks!
-GH
Unfortunately, its not possible to limit the size of the logfile - that would defeat the purpose of the the logfile : to log everything it does.
A workaround might be to write to a new logfile every X hours, so you write to several different named logfiles during the course of a day. Perhaps using the date to name the logfile, like this?
Regards,Code:SET log_fname=%prefix%%date:~-4,4%%date:~-10,2%%date:~-7,2%.log
Golden
Hi all,
I´ve create a .bat file with the help of this tutorial, to make a backup of a directorie to my Skydrive account, this is the script.
robocopy.exe "C:\Radio\DXLab" "C:\Users\userid\SkyDrive\Radio\DXLab Backups\teste" /e /mir /np /z /tee /log:backup_log.txt
Now what I was trying to do is:
Inside DXLab directorie is an Folder - Luncher, with an Luncher.exe, that lunches 7 applications, and when I terminate the Luncher.exe it terminates all 7 applications.
Now what I wanna do is when Luncher.exe close, the Backup.bat will make the backup of that session.
I've already converted .bat to .exe and the script works good.
Any ideia on how to do this.
Thanks.
I am hoping if someone can help me with a backup solution I have in mind.
I have a production site and an offsite.
Daily, I want to do a backup from production to offsite.
Challenge is, if files or folders are deleted from source, then the files/folders from destination must be MOVED to a folder in \\OffSiteServer\ShareName1\DELETED\<DateOfBackup>\path structure to file/folder.
Using the purge or mir does not work for me (for the moment) as it just purges off the data from destination. I need to keep the data for several years.
- The idea is to have a snapshot every beginning of the month. (Easy to manage this using \\OffsiteServer\ShareName1\<DateOfBackup>.)
- Next, incremental daily backup using /MAXAGE:1 (Easy to manage this as well using \\OffsiteServer\ShareName1\<DateOfBackup> and /MAXAGE:1)
- But the MOVING of files/folder from destination is something I cannot figure out how to achieve.
- The monthly snapshot is not to be touched as it is a snapshot as at that point in time. A comparison has to be done somehow if a file/folder has been deleted, then copy it from last available backup date to \\OffSiteServer\ShareName1\DELETED\<DateOfBackup>\path structure to file/folder. Additionally, it has to check in the \\OffSiteServer\ShareName1\DELETED subfolders that if it has been deleted already, it should not copy the file/folder into DELETED again (i.e. no multiple copies daily).
No, I do not have a script at the moment as I am lost at this point.
I would appreciate any help anyone can render at this moment.
Thank you all for your kind help.
Best Regards,
Ezra.
Last edited by Ezra NLV; 01 Jul 2013 at 03:28. Reason: Added elaborate explanation of deletion
Hi all:
Just need a little help with closing the window automatically. I run a .bat file that contains:
robocopy C:\Users\VA\Documents T:\ /mir /maxage:3 /r:0 /w:0 /np /mt /xf Backup-TC /log+:robobackuplog.txt
I would like the window to close automatically when done. Tried adding exit, didn't work. Any help is appreciated!
Try using :
Code:start "" robocopy C:\Users\VA\Documents T:\ /mir /maxage:3 /r:0 /w:0 /np /mt /xf Backup-TC /log+:robobackuplog.txt EXIT
It didn't work...any other ideas?
I attached a screen shot.
Thanks again.
