ROBOCOPY - Create Backup Script
Page 22 of 32 FirstFirst ... 122021222324 ... LastLast
  1. Posts : 3
    64 bit win 7 home premium
       #210
    It worked - sorry, I didn't see the "start" on your line.
    Thanks!
  2. Posts : 19,383
       #211
    Glad to be of service
  3. Posts : 7
    W7 64bit
       #212
    Robocopy Script
    Bill thank for the tutorial. I have a little problem and I would have some suggestion from you. I have done it and it works correctly if I run it in a manual mode. If I automate it as Task Scheduler it does not work. I receive a message (see attached) that the option instruction /log:backup_log.txt is not a valid parameter and the task does not start.
    The script should copy from a network drive <P> to a <E> storage drive.
    This the script I have done :
    robocopy "P:\Archivio Comune" "E:\Backups Archivio Comune" /e /mir /np /z /tee /log:backup_log.txt
    I have also modified the option instruction as /log:backup.txt but the result is the same.
    Do you have any idea why the it works in manual mode and not as automated Task Scheduled ?
    Thank in advance for you help and suggestion.
    Attached Thumbnails Attached Thumbnails ROBOCOPY - Create Backup Script-error-message.jpg
  4. Posts : 19,383
       #213
    Have you tried running the task with highest privileges?
  5. Posts : 7
    W7 64bit
       #214
    Robocopy
    Thank for the immediate replay and thank for the suggestion. Yes with the highest privileges the task works,no error ,it is createed the backup file but does not create the log.txt file in the same folder where there is the script. It may be in an other folder ? Thank a lot.
  6. Posts : 19,383
       #215
    Check the desktop? Is it there?
  7. Posts : 7
    W7 64bit
       #216
    Robocopy
    Non in the Desktop. When I run it manually the log.txt is created into the same folder of the script. I did a search in the C:\ but nowhere there is the log.tpx
  8. Posts : 19,383
       #217
    Try this:
    robocopy "P:\Archivio Comune" "E:\Backups Archivio Comune" /e /mir /np /z /tee /log: "P:\Archivio Comune\backup_log.txt"
    The logfile should now be saved to "P:\Archivio Comune
  9. Posts : 7
    W7 64bit
       #218
    Robocpy
    No way. With the last script you sent also in manual mode the backup.txt is not written. In both mode , manual and Task Schedule, the backup file is written but not the log.txt file.
  10. Posts : 19,383
       #219
    Try removing space between log: "P
