ROBOCOPY - Create Backup Script
Page 25 of 32 FirstFirst ... 152324252627 ... LastLast
  1. Posts : 33
    Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
       #240
    Hi, I just started using Robocopy to backup my files to my JBOD recently and I noticed that it does not copy anything in My Document folder. Here is the result log for Robocopy regarding the backup.
    Total Copied Skipped Mismatch FAILED Extras
    Dirs : 4287 0 4287 0 0 0
    Files : 34164 22831 11333 0 0 0
    Bytes : 107.783 g 90.408 g 17.375 g 0 0 0
    Times : 20:32:46 2:02:26 0:00:00 0:15:26
    Ended : Mon Sep 08 02:58:21 2014
    Even though it says that it copied 22831 files the destination folder says it has not been modified at all.
    The strange thing is that when I was checking back on the progress in the cmd window, it showed that it was copying files. The problem is I have no idea where those files went, the files that were supposedly copied aren't there at all. Here is the script I used to back up my files.
    robocopy F:\Anime G:\Anime /mir /copyall /np /tee /mt /log:"C:\Users\C.C\Desktop\my_backup_log.txt"
    robocopy "E:\Disk Backups" "G:\Disk Backups" /mir /copyall /np /tee /mt /log+:"C:\Users\C.C\Desktop\my_backup_log.txt"
    robocopy E:\Downloads G:\Downloads /mir /copyall /np /tee /mt /log+:"C:\Users\C.C\Desktop\my_backup_log.txt"
    robocopy E:\Movie G:\Movie /mir /copyall /np /tee /mt /log+:"C:\Users\C.C\Desktop\my_backup_log.txt"
    robocopy "C:\Users\C.C\My Documents" "G:\My Documents" /mir /copyall /np /tee /mt /log+:"C:\Users\C.C\Desktop\my_backup_log.txt"
    robocopy E:\Text G:\Text /mir /copyall /np /tee /mt /log+:"C:\Users\C.C\Desktop\my_backup_log.txt"
    pause
    The other folders seem to have been mirrored correctly, it's just the My Documents folder that is having this issue.
    I tried deleting the destination folder I currently had on the backup disk and ran robocopy again. It skipped right through the document script. It seems like it's saving somewhere but I don't know where. Here is the result.
    Files : 34163 0 34163 0 0 0
    Bytes : 107.783 g 0 107.783 g 0 0 0
    Times : 0:03:11 0:00:00 0:00:00 0:03:11
    Ended : Mon Sep 08 09:51:19 2014
  2. Posts : 1
    windows 8 64bit
       #241
    ROBOCOPY
    Can someone write me an robocopy script for the following;
    - copy a folder
    - different backup sets for each day
    - delete backups sets for each day when overwritten
    - also check for all files are being copied
    - backup log
    Thanks a million in advance
  3. Posts : 1
    Windows 7 Professional 64 Bit
       #242
    Robocopy commands fail in script not in command
    Hello,
    I have several ROBOCOPY commands in a script. 1 of the command lines fails when running it in the script.
    The error I receive is: ERROR 2 (0x00000002) Accessing Source Directory W:\sales\Bibliothèque sacs Holweg\ The system cannot find the file specified.
    When I run the ROBOCOPY command in the command window it executes flawlessly.
    Here is the specific command line: ROBOCOPY "W:\sales\Bibliothèque sacs Holweg" "d:\dept\sales\Holweg Transfer\Bibliothèque sacs Holweg" /MIR /COPY:dat /R:1 /W:1 /TEE /LOG:d:\Scripts\Logs\Hol_sales_2.txt
    Any suggestions?
    Thank you!
  4. Posts : 31
    Windows 7 Pro 64-bit
       #243
    As regards the template towards the end of the first post in this thread, I am curious as to what the following line means:
    rem --- The /mir option has been left out for safety sake
    Why is it more safe to disallow the creation of a new file alongside the original?
  5. Posts : 19,383
       #244
    When I first put this together, I was mistakenly under the impression that \mir could inadvertently delete the original source file, so I included that rem statement. I'll remove it from the template this evening.
  6. Posts : 31
       #245
    Actually, hold that thought...
    I ran a test trying to sort out my option switches. And files were actually deleted. Perhaps I can counter that by adding /XX. I will try.
    Sorry, was confusing source and destination.
    But what really surprised me was the log file that showed a host of switches that were not present in my command line. They seem to have defaulted in. Is that expected? If MIR is E+PURGE, then why are all three of them in the generated command line?
    robocopy "G:\musica\_lectures" "E:\##testrobot" /e /mir /np /tee /mt:4 /log:robocopy_backup_log.txt
    pause
    yielded:
       ROBOCOPY     ::     Robust File Copy for Windows
      Started : Thu Dec 11 23:26:47 2014
       Source : G:\musica\_lectures\
         Dest : E:\##testrobot\
        Files : *.*
      Options : *.* /TEE /S /E /COPY:DAT /PURGE /MIR /NP /MT:4 /R:1000000 /W:30
                           //// etc etc etc ////
  7. Posts : 4
    Windows 7 Professional, 64-bit
       #246
    How to locate skipped files in backup log
    Hi Golden,
    This is my first time using this program; your tutorial is the only thing I've come across that is actually helpful (I am not a tech person and other how-tos have assumed the reader is tech-savvy already).
    So, thank you for this!
    I was finally able to write a script that did what we want it to do; however, I noticed that it skipped a file/folder the second time, but hadn't skipped anything the first time.
    The difference between the first and second times are that on the second run, I'd added the /log: switch to create a log file.
    How can I find out what folders/files are skipped after a backup has been completed? Is there anything in the log that identifies skipped data?
    Thanks much,
    Jenee
  8. Posts : 19,383
       #247
    Can you paste a copy of your .bat and log file here, and I'll have a look at it for you?
  9. Posts : 4
       #248
    Sure, here is the .bat script:
    robocopy "J:\SOPs_from Public Drive" "H:\Work Stuff\SOPs\BACKUPS\SOP Public Backup as of 02-19-15" /E /tee /log:backup_log.txt
    robocopy "J:\Standard Operating Procedures_SOPs" "H:\Work Stuff\SOPs\BACKUPS\SOP Training Backup as of 02-19-15" /E /tee /log:backup_log.txt
    pause
    I will attach the log file because it is a LOT of data....you might even change your mind about looking through it for me, lol.
    ROBOCOPY - Create Backup Script Attached Files
  10. Posts : 5
    Windows 8.1 x64
       #249
    Script Doesn't Work
    I've tried this script verbatim with no luck. I even created the test directories manually, and the script still wouldn't work (Windows 7, Windows 10).
