System Icons - Enable or Disable
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. Posts : 41
    Windows 7 Ultimate x64-bit SP1
       #30
    Still Missing
    Shawn I have tried this post and this post Notification Area Icons - Reset and it's still not bring back the Action Center Flag.
    Also did SFC/SCANNOW and nothing.
    Still missing in the taskbar
    and not able to turn it on.
    Any help will do thanks again...
    Kevin
    Attached Thumbnails Attached Thumbnails System Icons - Enable or Disable-capture.jpg   System Icons - Enable or Disable-capture2.jpg
  2. Posts : 72,059
       #31
    Hello Kevin,
    You might see if doing a system restore using a restore point (if available) dated before this happened may be able to undo and fix this for you.
  3. Posts : 41
       #32
    Already did a Repair Install everything is fixed now thanks Shawn
    Kevin
  4. Posts : 72,059
       #33
    That was quick, but great news. :)
  5. Posts : 86
    Microsoft Windows 7 Professional Edition Service Pack 1 (build 7601), 64-bit
       #34
    I came to this thread because I am having an odd thing .. both my anti-virus and my Skype icons are no longer showing up and I did everything except system restore. I did run Malware Bytes and I have no malware (I have the valid Pro version I paid for and I updated it just before scanning even though I have it set to always update). Both the anti-virus and Skype are running. Take a look at the screenshot showing Skype and the Icons option.
    Attached Thumbnails Attached Thumbnails System Icons - Enable or Disable-skype_task_bar_notification_icon_not_showing_up_suddenly.jpg
  6. Posts : 72,059
       #35
    Hello kabo0m,
    This tutorial is for the default system icons instead, and wouldn't apply to your issue. You might see if resetting the notification area icons may help.
    Otherwise, you might see if uninstalling and reinstalling the affected programs may fix this.
    Hope this helps, :)
  7. Posts : 86
       #36
    Thanks that seemed to help. :)
  8. Posts : 72,059
       #37
    You're most welcome kabo0m. I'm glad to hear you got it sorted. :)
  9. Posts : 1
    windows 7 ultimate 64bit sp1
       #38
    my system notifications are grayed out in the customization menu of th
    I HAVE TRIED ALL UR STEP BUT STILL BRINK MY SYSTEM ICONS ARE GRAYED OUT ..THE FOLLOWING ICONS R GRAYED OUT ACTION CENTRE ICON,NETWORK ICON,VOLUME ICON ,,,,,,I AM BADLY IN NEED OF THOSE ICON ....SO KINDLY COULD U PROVIDE ME WITH A SOLUTION TO THIS PROBLEM.......
    I USE A LAPTOP WITH WINDOWS 7 ULTIMATE .64 BIT.SP 1....I TRIED TO RESET THE NOTIICATION ICON ,,THE CMD RESTORE THE DOWNLOAD REG FILES ...AND ALL THE STEPS GIV BUT STILL NO USE......
    I LOOK FORWARD TO HEAR FROM U SOON.....IF POSSIBLE WITH AN HOUR.......
  10. Posts : 72,059
       #39
    Hello Aakash, and welcome to Seven Forums. :)
    Please go ahead and post a screenshot showing all of your "System Icons" settings window to see if it may help reveal a cause.
    Just to clarify, you did already try the "Enable" .reg files in OPTION TWO and restarted the computer afterwards?
    Are you logged in to an administrator account?
