System Icons - Enable or Disable
Page 6 of 6 FirstFirst ... 456
  1. Posts : 3
    windows 7 home premium
       #50
    VPCF23P1E
  2. Posts : 72,051
       #51
    l00097 said:
    VPCF23P1E
    Here's the driver download page below at Sony for that model number. You can just double check to make sure that you have them installed, and at least the same or newer driver version of them in the Device Manager.
    Sony Support
    In addition, you might see if removing and connecting the battery may toggle it to show up afterwards. :)
  3. Posts : 5
    Windows 7 Ultimate 32 bit
       #52
    I have tried EVERYTHING still cannot see battery
    l00097 said:
    I have spent about two hours trying to access my battery icon as it has been disabled for a couple of days now (possibly more, and I have absolutely no idea why!), I have done the following: downloaded the REG file; tried to access it from the administrative account; and use task manager to end the explorer.exe process and type in the systray.exe process. Nothing has worked!
    It's really frustrating because if I haven't got my computer plugged in, I am unaware if it is lower than 10% battery so it will just cut out in the middle of the work I am doing.
    PLEASE HELP!!!
    download the installer for your system this will give you info about state of your battery.
    HWiNFO, HWiNFO32/64 - Download
  4. Posts : 1
    windows 10 64 bit
       #53
    Solved
    Thank you Problem solved . I applied it on Windows 10 64bit
