Windows 7: Take Ownership Shortcut
13 May 2018   #380
fanfan98
Win 7 Pro x64
Hi Mr Brink, I'm running Windows 7 Pro 64 bits sp1 in French, where I can get the correct version of your shortcut
take ownership,
thanks in advance
13 May 2018   #381
Brink
64-bit Windows 10 Pro
Hello @fanfan98, and welcome to Seven Forums. :)
Here's a French version below for you.
French-Add_Take_Ownership_with_Pause_to_context_menu.reg
13 May 2018   #382
fanfan98
Win 7 Pro x64
Thank you
13 May 2018   #383
Brink
You're most welcome. :)
13 May 2018   #384
fanfan98
Win 7 Pro x64
I just have a last question for you...
If in the future I want to remove the Take Ownership menu, can I do it with the reg file supplied on the first page of this thread or do I need a French version ?
13 May 2018   #385
Brink
Correct. You can use the same .reg file in the tutorial to remove the context menu.
13 May 2018   #386
fanfan98
Win 7 Pro x64
Thanks a lot.
And thank you also for your tutorial about Win 7 repair installation. It saved my life this weekend and my computer is now working like a charm
18 Jul 2018   #387
shurzota
Hello Brink,
I added “Take Ownership” with Pause to context menu. Setting ownership and permission was successful for any uncorrupted file on my PC and I always got “SUCCESS: The file…” cmd window - similar to the picture from the step #3 of you instruction. But setting ownership and permission was NOT successful for corrupted .asf file. I got empty, black cmd window. I cannot delete this .asf file, located in Computer\(D:)\Name\My Videos. I moved My Documents, My Music, My Pictures, My Videos folders from C: drive to D: drive.
18 Jul 2018   #388
Brink
Hello shurzota,
You might see if the free program Unlocker or FileASSASSIN may be able to delete the file for you.
19 Jul 2018   #389
shurzota
Thank you very much for you amazing work. I created entire library from your posts. Your explanations are so good, that many IT professors could envy the clarity of presentation.
Custom 'Desktop (create shortcut)' Remove .fileextension - Shortcut
Hi guys n girls, I have for ever got sick and tired of right click -> open Send to Menu and creating a Desktop Shortcut for a file or app....then needing to go to the Desktop right click the newly made shortcut and then removing the trailing file extension, dash and words shortcut in brackets....
Customization
Creating a shortcut without - shortcut written after the original name
as the titel declares, is there any patch or something to make Windows 7 shortcuts not rename theirselves to "application.exe - shortcut" but rename theirselves into just "application.exe"? I find it very annoying having to erase " - shortcut" from the name all the time.
General Discussion
Ownership for XP
Dear helpers ,, i am using windows XP and previously i was using win7 it was not properly supported on my pc , i had forbidden some folders for users other than Administrator, how can i get ownership of those folders on XP , i have tried the "Take_Ownership.reg" and followed the procedure it just...
Chillout Room
ownership and uac
I have my UAC all the way down and cannot figure how to take ownership of folders. I have a windows.old and a windows.old.000 and I want to delete one of them. Thanks!
General Discussion
Twitter Facebook
