Windows 7: Take Ownership Shortcut
06 Jun 2019   #410
neroruiz
windows 10 64 bit
tradução
Por favor conseguiriam traduzir o post para Portugues/Brasil
06 Jun 2019   #411
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by neroruiz View Post
Hello neroruiz, and welcome to Seven Forums.
Here's a Portuguese version.
Portuguese_Add_Take_Ownership_to_context_menu.reg
18 Oct 2019   #412
didus69
most of all
Hello,
thank you for the french version found on 39 page
best regards
18 Oct 2019   #413
Brink
Quote   Quote: Originally Posted by didus69 View Post
Hello,
best regards
Welcome to Ten Forums didus69. I'm glad it could help.
Custom 'Desktop (create shortcut)' Remove .fileextension - Shortcut
Hi guys n girls, I have for ever got sick and tired of right click -> open Send to Menu and creating a Desktop Shortcut for a file or app....then needing to go to the Desktop right click the newly made shortcut and then removing the trailing file extension, dash and words shortcut in brackets....
Customization
Creating a shortcut without - shortcut written after the original name
as the titel declares, is there any patch or something to make Windows 7 shortcuts not rename theirselves to "application.exe - shortcut" but rename theirselves into just "application.exe"? I find it very annoying having to erase " - shortcut" from the name all the time.
General Discussion
Ownership for XP
Dear helpers ,, i am using windows XP and previously i was using win7 it was not properly supported on my pc , i had forbidden some folders for users other than Administrator, how can i get ownership of those folders on XP , i have tried the "Take_Ownership.reg" and followed the procedure it just...
Chillout Room
ownership and uac
I have my UAC all the way down and cannot figure how to take ownership of folders. I have a windows.old and a windows.old.000 and I want to delete one of them. Thanks!
General Discussion
Twitter Facebook
