#170
Yep, that would be correct.
thanks
i did a mistake and i take ownership of w7 disk and xp
can i undo?
thanks
Hello Drugo,
Oh my. Are you having any issues from doing this? If not, then I wouldn't worry about it.
If your are, then you could try doing a system restore at boot using a restore point dated before you did this to hopefully undo it in Windows 7. I'm not sure what the procedure is for in XP though.
This script is the bomb! I can finally delete things again after trying everything Microsoft and other forums suggest!
Drugo,
Yes, if done used on a drive, it will change the ownership of every file and folder on the drive to you, and set the permissions of every file and folder to "Allow" you "Full Control".
This could cause issue unknown issues with system access to these files, folders, or drive afterwards.
Yep, it's scary that it doesn't take long to do it. Hopefully, you'll be ok and will not have any issues from doing so.
i restored an w7 image
but i have not an image about xp
is there a way /tool /test to know that everything is ok ?
by the way i'm right Take Ownership change all the permissions to normal user? right?
thanks
you are always very kind
EDIT:
do you know i'm thinking about Ultimate Windows Tweaker
it can show Take Ownership only for files or folder
a new script reg key , for files only or/and folder would be less dangerous
thanks
cheers
