Take Ownership Shortcut
Page 22 of 45 FirstFirst ... 12202122232432 ... LastLast
  1. Posts : 72,051
       #210
    leftygt said:
    Hi Shawn
    Thanks for your help.I tried unlocker, but its telling me there is no "unlocking handle"?
    You might see if temporarily moving the contents back to the original location may allow you to then be able to un-share and delete it.
    If not, then I would recommend to go ahead and post this issue in the Network & Sharing forum area to see what we may be able to do to help with there it since it's not related with this tutorial. This way you will get more specific help with it. :)
  2. Posts : 1
    Windows 7 Home Premium 32bit.
       #211
  3. Posts : 1
    WINDOWS 7 HOME EDITION 32 BIT
       #212
    Thanks... it worked... was trying for since million years... ( I think So) thanks again...
  4. Posts : 1
    Windows 7 Home Premium 64 bit
       #213
    THANKS A MILLION
    I had problems with iTunes showing the error message (-42404) part of iTunes not installed correctly etc.
    I was advised to look at your posting re this problem - I downloaded the TAKE OWNERSHIP prog, followed your instructions and PROBLEM SOLVED.
    Many, many thanks - Apple offered no such advice - I was tearing my hair out.
    WELL DONE ONCE AGAIN.
    Regards
    Signman3
  5. Posts : 19
    windows7 ultimate x32
       #214
    via cmd
     @echo off
    reg query "HKU\S-1-5-19\Environment"
    If Not %ERRORLEVEL% EQU 0 (
     cls & echo Schadenfreude..
     Pause & Exit
    Cls
    echo  Take Ownership:
    reg delete "HKCR\*\shell\runas" /f
    reg add "HKCR\*\shell\runas"         /ve                        /d "Take Ownership" /f
    reg add "HKCR\*\shell\runas"         /v "HasLUAShield"          /d ""               /f
    reg add "HKCR\*\shell\runas"         /v "NoWorkingDirectory"    /d ""               /f
    reg add "HKCR\*\shell\runas"         /v "Position"              /d "middle"         /f
    reg add "HKCR\*\shell\runas\command" /ve                        /d "cmd.exe /c takeown /f \"%%1\" && icacls \"%%1\" /grant *S-1-3-4:F /c /l & pause" /f
    reg add "HKCR\*\shell\runas\command" /v "IsolatedCommand"       /d "cmd.exe /c takeown /f \"%%1\" && icacls \"%%1\" /grant *S-1-3-4:F /c /l & pause" /f
     reg delete "HKCR\Directory\shell\runas" /f
     reg add "HKCR\Directory\shell\runas"         /ve                     /d "Take Ownership" /f
     reg add "HKCR\Directory\shell\runas"         /v "AppliesTo"          /d "NOT (System.ItemPathDisplay:=\"C:\Users\" OR System.ItemPathDisplay:=\"C:\ProgramData\" OR System.ItemPathDisplay:=\"C:\Windows\" OR System.ItemPathDisplay:=\"C:\Windows\System32\" OR System.ItemPathDisplay:=\"C:\Program Files\" OR System.ItemPathDisplay:=\"C:\Program Files (x86)\")" /f
     reg add "HKCR\Directory\shell\runas"         /v "HasLUAShield"       /d ""       /f
     reg add "HKCR\Directory\shell\runas"         /v "NoWorkingDirectory" /d ""       /f
     reg add "HKCR\Directory\shell\runas"         /v "Position"           /d "middle" /f
     reg add "HKCR\Directory\shell\runas\command" /ve                     /d "cmd.exe /c takeown /f \"%%1\" /r /d y && icacls \"%%1\" /grant *S-1-3-4:F /t /c /l /q & pause" /f
     reg add "HKCR\Directory\shell\runas\command" /v "IsolatedCommand"    /d "cmd.exe /c takeown /f \"%%1\" /r /d y && icacls \"%%1\" /grant *S-1-3-4:F /t /c /l /q & pause" /f
    reg delete "HKCR\dllfile\shell\runas" /f
    reg add "HKCR\dllfile\shell\runas"         /ve                     /d "Take Ownership" /f
    reg add "HKCR\dllfile\shell\runas"         /v "HasLUAShield"       /d ""               /f
    reg add "HKCR\dllfile\shell\runas"         /v "NoWorkingDirectory" /d ""               /f
    reg add "HKCR\dllfile\shell\runas"         /v "Position"           /d "middle"         /f
    reg add "HKCR\dllfile\shell\runas\command" /ve                     /d "cmd.exe /c takeown /f \"%%1\" && icacls \"%%1\" /grant *S-1-3-4:F /c /l & pause" /f
    reg add "HKCR\dllfile\shell\runas\command" /v "IsolatedCommand"    /d "cmd.exe /c takeown /f \"%%1\" && icacls \"%%1\" /grant *S-1-3-4:F /c /l & pause" /f
     reg delete "HKCR\Drive\shell\runas" /f
     reg add "HKCR\Drive\shell\runas"         /ve                     /d "Take Ownership" /f
     reg add "HKCR\Drive\shell\runas"         /v "AppliesTo"          /d "NOT C:"         /f
     reg add "HKCR\Drive\shell\runas"         /v "HasLUAShield"       /d ""               /f
     reg add "HKCR\Drive\shell\runas"         /v "NoWorkingDirectory" /d ""               /f
     reg add "HKCR\Drive\shell\runas"         /v "Position"           /d "middle"         /f
     reg add "HKCR\Drive\shell\runas\command" /ve                     /d "cmd.exe /c takeown /f \"%%1\" /r /d y && icacls \"%%1\" /grant *S-1-3-4:F /t /c /l /q & pause" /f
     reg add "HKCR\Drive\shell\runas\command" /v "IsolatedCommand"    /d "cmd.exe /c takeown /f \"%%1\" /r /d y && icacls \"%%1\" /grant *S-1-3-4:F /t /c /l /q & pause" /f
    reg delete "HKCR\exefile\shell\runas" /f
    reg add "HKCR\exefile\shell\runas"         /v "HasLUAShield"    /d ""            /f
    reg add "HKCR\exefile\shell\runas\command" /ve                  /d "\"%%1\" %%*" /f
    reg add "HKCR\exefile\shell\runas\command" /v "IsolatedCommand" /d "\"%%1\" %%*" /f
    :: or "/grant administrators:F" instead "/grant *S-1-3-4:F"
    pause & exit
  6. Posts : 1
    Windows 7 Professional X64
       #215
    This is truly wonderful.
    For a while I was dual booting windows but the "older" version of Windows 7 was no longer needed.
    Getting rid of the disk space was nearly impossible until I found this.
    Thanks!
  7. Posts : 2
    Win 7
       #216
    Hey guys, any idea where the reg file / install is and how one may go about altering the value for the maximum number of folders to perform Take Ownership on at once? I know your can just do a whole drive and wait that way, but its just a bunch of cmd operations, shouldn't be capped like that :/
  8. Posts : 72,051
       #217
    Hello Jobo, and welcome to Seven Forums.
    That would be the 15 selected limit that's universal in Windows 7. You can use the tutorial below to set this to be unlimited instead. :)
    Context Menu Items Missing - Fix when more than 15 Files are Selected
  9. Posts : 2
    Win 7
       #218
    Shawn, thats perfect... too easy
    Cheers!
  10. Posts : 72,051
       #219
    You're most welcome Jobo. :)
