Take Ownership Shortcut
Page 26 of 45 FirstFirst ... 16242526272836 ... LastLast
  1. Posts : 72,052
       #250
    chazcon said:
    Brink said:
    Hello Chazcon,
    OPTION THREE in the tutorial below can show you how to manually set ownership and permission of items.
    I would recommend that you create a restore point first. This way if you make a mistake, you could do a system restore to quickly undo it.
    Hope this helps, :)
    Thanks Brink, I'm using a reg tweak (Mark's from these forums) to take ownership. But it's more than that.
    Background info: I have (3) computers, work desktop, personal desktop, and a laptop for travel. One has Windows 8 (which is horrible and I will be changing out to Windows 7 this week), the other two Windows 7. I work variously off all three computers. So I use Synchronize It! and sync to a flash drive that I pack around with me.
    I've used this 3rd party app and my flash drive system for years. Our company currently does not operate off a MS Exchange server which would make our lives easier, all working off central files but I am working on that.
    Anyway, my problem is I'll sync my work PC to my flash drive, go to my home computer, attempt a sync and it won't open some files that have the ownership of my work login and not my personal login. Or, vice versa, i'll work from my home PC and sync, go to the office and I can't access my changed files. It's becoming hell and I'm wondering what has changed recently for me, I rarely had this issue in the past.
    I'm scowling at Windows 8 but truly it must be a user issue. One thing I've changed recently is to format my flash drive from FAT32 to NTFS in order to be able to sync my Outlook.pst file, which is very large and over the FAT32 allowable size limit for a single file. I suspect that my flash drive formatted in NTFS now is also carrying over NTFS permissions where it didn't before on FAT32 - does that sound like a possible cause?
    Also in Synchronize It! there is an option to 'Copy NTFS Permissions', I'm in a quandry now whether I should or should not be copying permissions.
    How I wish I could turn permissions and permission checks completely off! I have the UAC off but that is a separate thing.
    Each time I sync I have to go through my files and take ownership, it's a time killer and I have no time to do this.
    I'd love to know of a 3rd party app that can manage permissions across all files and multiple computers.
    Chazcon,
    Yep, if it's NTFS formatted, then permissions will be applied to it as well.
    You might give using "Synchronize It" a try without the 'Copy NTFS Permissions' option. It may be replacing any previous permission settings you made for it.
    You might also add the "Everyone" group and set it's permissions to "Full Control" to see if that may help.
  2. Posts : 12
    Windows 7 Ultimate 64-bit
       #251
    Brink said:
    Chazcon,
    Will try those options.
    To be clear, if my flash drive is formatted as FAT32, it will basically 'scrub' permissions from files that are copied to it? That is how my syncing 'system' used to work, I seems I didn't have this permission hell when it was formatted FAT32. If that's true I'll go back to FAT32 on my flash drive and use a different solution for my large files that are over the FAT32 single file size limit.
  3. Posts : 72,052
       #252
    Yep, that's correct.
  4. Posts : 313
    Vista/Win7/8/10/11 (x86/x64)
       #253
    Hey Hi Brink,
    Just wanted to run this by you.
    Using your ditty I was just going to take ownership of a single folder inside of
    C:\Windows\System32\DriverStore\FileRepository
    ...and delete it, but it's late and in a hurry I mistakenly right clicked on the whole FileRepository folder instead and took ownership of that whole folder instead, LoL, and it went through and did exactly that. I didn't delete anything at that point.
    My question is I don't think it really matters and won't hurt anything taking ownership of that entire FileRepository folder will it?
    If yes I can easily restore the OS partition image back to yesterday if it does matter, that's no big deal, but I wanted to ask you about the specifics just to make sure.
  5. Posts : 72,052
       #254
    Hey mate,
    It's not going to make any difference other than that folder and it's contents being less secured now that anything running while you are logged on to your account will also have access to it.
    If you happen to have a restore point dated right before you did it, then a system restore using it could quickly undo it.
    I don't see a need to do a system image recovery unless you just wanted to though.
  6. Posts : 313
       #255
    Hi Brink,
    During work today I had decided I was just going to do a partition restore, luckily I just had made an image the very day before so it's no big deal and takes just a few minutes.
    My local System Restore is always turned off.
    It wouldn't hurt anything to leave it I know that, but it's just the principle I guess, and that I had only meant to do it on a single folder inside the FileRepository folder not the whole darn thing.
    I had downloaded my reg at the Vista forum previously, but I see you have it here on 7 too.
    fwiw, the screenshot of it on page 1 is a little different than reality, and so must of been the first builds screenshot from Mark where you hadn't yet added in the context icon via imageres.dll yet. Okay but I see you have the icon'd screenshot over at the Vista forum.
    Anyway, nice to say hello again and thanks for the reply
  7. Posts : 72,052
       #256
    Screenshot now updated. :)
  8. Posts : 12
       #257
    Quick update: All is well, after going back to a FAT32 format on my flash drive. Also I realize we are able to set a different (larger) file allocation size, so now I have what I needed, a flash drive file sync solution that handles my large files as well, with no NTFS permission hell.
    Brink, thank you for your help.
  9. Posts : 72,052
       #258
    That's great news Chazcon. Thank you for posting back with your results. :)
  10. Posts : 1
    widows 7 ultimate x86
       #259
    ohhhh yyyyyyyyyes !!!!
    thanks so much...
