#20
Wow, Mr. Grim + Brink, thanks sooo much!!!
I pulled my hair out and tried everything to get access because of those weird problems with one folder, now this helped me immediatly! I'm so grateful! :)
I have a dual boot system with Vista and 7.
The C drive is the vista drive and some storage
7 is installed on Q
Working in 7 one day, for some reason I decided it would be a good idea to 'take control' of the C (Vista) drive so that I could access some files.
Next time I booted to vista though, I now have huge problems with accessing the C drive. I cant install soem apps; I cant change the security or ownership settings because I dont have access to C and I am starting to get very frustrated.
I have tried the take control download and the command line alternative, but both tell me that I don not have access to the C drive
Can anyone please help.
Hello Andy, and welcome to Seven Forums.
You will need to restore the owner to TrustedInstaller for the Vista partition. You may need to do this from within Windows 7 since you changed the owner in Windows 7 though.
Thanks for the suggestion- not tried it out yet - I seem to be busy with work!
May have time tommorrow
Andy
Registered just to thank you for this great hack, really needed this to delete an old WIN7 installation since I've tried everything and no luck.
Thanks again!
easy way to remove windows.old
Windows.old Folder - Delete
1. my computer
2. right click c:
3. scrowl down to properties
4. disc cleanup
5. clean up system files
6. more options
7. down to system restore and shadow copies.
THIS will removed Windows.old and all othe other unneeded files.
(The Microsoft way.)
8. click cleanup - and away we go....
ENJOY
