Take Ownership Shortcut
Page 33 of 45 FirstFirst ... 23313233343543 ... LastLast
  1. Posts : 72,051
       #320
    Hello ezwin, :)
    You might see if you may be able to use the free program Unlocker to delete them.
  2. LTH
    Windows 7 Professional X64
       #321
    I know this a very old topic but I've been fighting this problem for some time now and I'm going give this a try. My question is this, after I apply the Take Ownership to a folder and later want apply the Remove Ownership does the folder and files revert back to the original setting or would I have to do a system restore to do that? Thx for any help with this.
  3. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #322
    Hi LTH and welcome to SevenForums
    As far as I know no
    The removal only removes the take ownership from the context menu not from what you have used it on.
    So yes you would have to use system restore to undo.
  4. LTH
       #323
    Thanks ThrashZone for the reply. After reading a little farther I think I might have screwed up. I took ownership of my c:/users/****** folder and from what I reading now I can't reverse this even with a system restore. I hope I'm wrong and this can be reversed and someone can tell me how to do this. My fault though I should have done a little more research before diving in.
  5. Posts : 20,583
       #324
    This is for personal files/folders mainly not for entire drives unless you're intending on doing a clean install of the os
    Brink may know a trick or two :/
  6. Posts : 721
    Windows 10, Windows 8.1 Pro, Windows 7 Professional, OS X El Capitan
       #325
    I haven't tested myself, but from what I've read a System Restore will never attempt to undo permission changes.
    LTH, is there a particular problem you are facing after running Take Ownership Shortcut on your user profile directory?
    The Take Ownership Shortcut, when applied on a directory, will change the owner of that directory, subdirectories and files, and will also add an Administrators ACE to them all.
    The files and folders under the directory of which you applied the Take Ownership Shortcut to (C:\Users\MyUser), LTH, typically already have the same permissions and ownership settings that the reg tweak applies anyway, so having run the TO-Shortcut should have pretty much done nothing, and you shouldn't notice any difference since applying it.
    Be careful when altering file owners and permissions as there is no easy 'back' button if you happen make a mistake.
  7. Posts : 1
    On my Win10 pro x64 1151, the reg entry add Take Ownership at the top of context, as default.
    all double clicks would run take ownership. oops. good thing we have the remove reg file
    is there a fix?
  8. Posts : 313
    Vista/Win7/8/10/11 (x86/x64)
       #327
    This is the Windows Seven Forums.
    ..anyway, since I got this threads post notice in my email I'll say a few things here.
    On Windows 10 for me just installing it whether using the regular or pause version, works just fine, and certainly all double clicks do not run take ownership - it's not even close.
    Add to Context Menu in Windows 10 - Windows 10 Forums
  9. Posts : 161
    Windows 7 Home Premium 64 bit
       #328
    Shawn,
    I had a need to access the C:\Recovery folder to create a Win 7 System Repair USB stick so I used your Reg download to get ownership from the right-click context menu. Worked great :)
    Thanks again for these tutorials.
  10. Posts : 72,051
       #329
    You're most welcome Scoop. I'm glad it could help. :)
