Take Ownership Shortcut
Page 39 of 45 FirstFirst ... 293738394041 ... LastLast
  1. Posts : 4
    Win 7 Pro x64
       #380
    Hi Mr Brink, I'm running Windows 7 Pro 64 bits sp1 in French, where I can get the correct version of your shortcut
    take ownership,
    thanks in advance
  2. Posts : 72,052
       #381
    Hello @fanfan98, and welcome to Seven Forums. :)
    Here's a French version below for you.
    French-Add_Take_Ownership_with_Pause_to_context_menu.reg
  3. Posts : 4
    Win 7 Pro x64
       #382
    Thank you
  4. Posts : 72,052
       #383
    You're most welcome. :)
  5. Posts : 4
    Win 7 Pro x64
       #384
    I just have a last question for you...
    If in the future I want to remove the Take Ownership menu, can I do it with the reg file supplied on the first page of this thread or do I need a French version ?
  6. Posts : 72,052
       #385
    Correct. You can use the same .reg file in the tutorial to remove the context menu.
  7. Posts : 4
    Win 7 Pro x64
       #386
    Thanks a lot.
    And thank you also for your tutorial about Win 7 repair installation. It saved my life this weekend and my computer is now working like a charm
  8. Posts : 16
    Hello Brink,
    I added “Take Ownership” with Pause to context menu. Setting ownership and permission was successful for any uncorrupted file on my PC and I always got “SUCCESS: The file…” cmd window - similar to the picture from the step #3 of you instruction. But setting ownership and permission was NOT successful for corrupted .asf file. I got empty, black cmd window. I cannot delete this .asf file, located in Computer\(D:)\Name\My Videos. I moved My Documents, My Music, My Pictures, My Videos folders from C: drive to D: drive.
  9. Posts : 72,052
       #388
    Hello shurzota,
    You might see if the free program Unlocker or FileASSASSIN may be able to delete the file for you.
  10. Posts : 16
    Thank you very much for you amazing work. I created entire library from your posts. Your explanations are so good, that many IT professors could envy the clarity of presentation.
