Take Ownership Shortcut
Page 40 of 45 FirstFirst ... 303839404142 ... LastLast
  1. Posts : 72,051
       #390
    Thank you for the kind words shurzota. I'm glad they could help.
  2. Posts : 2
    Win 7 x64
       #391
    Take ownership in French
    FR:
    Bonjour,
    Est il possible d'avoir une version francaise de "Take Ownership Shortcut" ?
    Win7 Ultimate x64
    Merci d'avance
    Cordialement.
    ENtranslate auto)
    Hello,
    It is possible to have a French version of "Take Ownership Shortcut" ?
    Win7 Ultimate x64
    Thank you in advance
    Cordially
    Mic Geo
  3. Posts : 2
    Win 7 x64
       #392
    I dowloaded the link Page 39
    Afflicted !
    Thank you
    Mic Geo
  4. Posts : 72,051
       #393
    Welcome to Seven Forums Mic Geo.
  5. Posts : 1
    Windows 7 64Bit
       #394
    I've just registered to send a big thanks from Portugal for you kind help and coding!
    Obrigado,
    David
  6. Posts : 72,051
       #395
    You're most welcome David, and welcome to Seven Forums.
  7. Posts : 1
    Windows 7 Ultimate 32bit
       #396
    WoW Shawn!
    It's "unbalivable" how many people have hi-jacked your thread for their own issues. More than once I would have told them to open a new issue thread and erased their post... Go call Microsoft!
    It's a know When a thread is posted on a subject specified by the OP (Original Post(er)), the OP owns the thread and no one as any business using it to solve their own personal issues. The gentlemen with the encrypted files on page 16 is a flagrant example.
    That being said, I'm puzzled by all the different code used to generate a "Take Ownership" context menu item.
    Your code is under HKCR\*\shell\runas
    The keys I ran before were in HKCR\*\shell\takeownership
    Since to open command window as admin, usually, HKCR\Directory\shell\runas is used...
    Why do you use runas? Or is their actually any difference?
    Thank You for all your work... and for all your patience.
    Gilles
  8. Posts : 72,051
       #397
    Hello Gilles, and welcome to Seven Forums.
    I prefer the updated version below that will still work in Windows 7.
    Add Take Ownership to Context Menu in Windows 10 | Windows 10 Tutorials
    The "runas" key allows the context menu to run elevated to be able to successfully run its command. This however removes the "Run as administrator" context menu for application files.
    Otherwise, you have to use a method like I used in the newer version of the context menu.
  9. Posts : 1
    Brescia
       #398
    Good moorning,
    Congratulations.
    Can I have Add_Take_Ownership_to_context_menu for Italian system.
    Thank you very much
  10. Posts : 72,051
       #399
    Hello @mgmarposs, and welcome to Seven Forums.
    Here you go.
    Italian_Add_Take_Ownership_to_context_menu.reg
