Take Ownership Shortcut
Page 4 of 45 FirstFirst ... 2345614 ... LastLast
  1. Posts : 72,084
       #30
    You're welcome Badwolve from Mr. Grim (aka: Mark) and me. :)
  2. Posts : 77
    7 Home Premium x86
       #31
    Many thanks to you Mr GRiM!
  3. Posts : 353
    Win 7 Ultimate x64
       #32
    Just curious as I am wanting to learn about the behaviors of Windows 7 as I never played with Vista prior to this.
    How is it that some folders/files get messed up with ownership issues?
    For example, I am dual booting win xp and 7 and have another massive partition for files/media. I decided to reformat and install win 7 again. Upon doing so, I had ONE issue with a folder I keep all my music in on the massive partition. my mediamonkey couldn't access the files and when I navigated there I noticed a little lock symbol on the folder. manually I took ownership (I am now going to install this hack!) and this seemed to have fixed the issue.
    But how did that happen?
    Thanks for this registry tweak btw! great work.
  4. Posts : 202
    Windows 8.1 x64 Enterprise
       #33
    nice work Brink, this is very usefull and easy to use...
    also i want to ask u this: i want to change my start menu button so i have to take ownership of the entire Windows folder, are there any issues with this action or i can do it with no repercussions in the future ?
  5. Posts : 1,179
       #34
    It is not a HACK!
    To A320
    1st It is not a HACK. it is well documented in Microsoft Scripts.
    Open cmd prompt as admin
    type TAKEOWN /?
  6. Posts : 72,084
       #35
    Hello Maranello,
    You'll be fine with no problems after doing it.
    Start Menu Button - Change
  7. Posts : 3
    thanks again....
  8. Posts : 1
    windows 7
       #37
    Snuffy said:
    Seth81 said:
    Registered just to thank you for this great hack, really needed this to delete an old WIN7 installation since I've tried everything and no luck.
    Thanks again!
    easy way to remove windows.old
    Windows.old Folder - Delete
    1. my computer
    2. right click c:
    3. scrowl down to properties
    4. disc cleanup
    5. clean up system files
    6. more options
    7. down to system restore and shadow copies.
    THIS will removed Windows.old and all othe other unneeded files.
    (The Microsoft way.)
    8. click cleanup - and away we go....
    ENJOY
    thanks..
  9. Posts : 308
    Windows 7 Professional (x64)
       #38
    I'm currently trying to remove the read-only attributes for my Windows XP Mode base file so that I can merge the differencing disks in order to import into VMLite. I followed the intructions, but after I take ownership, I get the access denied message and click continue, then I get the Error Applying Attributes message shown below. Any thoughts?
  10. Posts : 72,084
       #39
    Hello HughShaw,
    You will still need to Allow your account "Full Control" of the file after taking ownership to be able to. Step 17 on in the tutorial below can help show you more on this if needed.
    Take Ownership of file - Vista Forums
