Take Ownership Shortcut
Page 9 of 45 FirstFirst ... 789101119 ... LastLast
  1. Posts : 72,085
       #80
    You're welcome. I'm happy to hear that you got it sorted. :)
  2. Posts : 4
    windows 7
       #81
    It works. Thanks a lot!
    Daniel
  3. Posts : 343
    this seems to be broken when also using the open elevated command window tweak, it appears to not auto elevate correctly for some reason.
    edit,
    strange i must've been using an older version or something
  4. Posts : 72,085
       #83
    Hello Danial,
    Yes, you have a older version. The current download had been updated not to long ago to cleanly remove and replace the Open Command Window Here as Administrator context menu item. :)
  5. Posts : 343
    i modified it some more to add the LUA shield to directories xD
    elevated cmd windows im not to worried about, i can launch them from total commander just by running that elevated xD
  6. Posts : 72,085
       #85
    Good idea. Updated downloads with to have the icon as well.
  7. Posts : 48
    Does this replace the "Run as Administrator" option?
  8. Posts : 343
    no.
  9. Posts : 48
    squall leonhart said:
    no.
    Hmmm.. I don't see it anymore when I right click.
  10. Posts : 343
    hmm, you're right, run as admin is broken D:
    but i know i had a self elevating take ownership item that worked fine with the run as admin command not so long ago.
    seems to be because it replaces the run as key for exe's.
    i recommend removal of take ownership over exe files?
    [-HKEY_CLASSES_ROOT\*\shell\runas]
    [HKEY_CLASSES_ROOT\*\shell\runas]
    @="Take ownership"
    "HasLUAShield"=""
    "NoWorkingDirectory"=""
    [HKEY_CLASSES_ROOT\*\shell\runas\command]
    @="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
    "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
    [-HKEY_CLASSES_ROOT\Directory\shell\runas]
    [HKEY_CLASSES_ROOT\Directory\shell\runas]
    @="Take ownership"
    "HasLUAShield"=""
    [HKEY_CLASSES_ROOT\Directory\shell\runas\command]
    @="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
    "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
    [-HKEY_CLASSES_ROOT\dllfile\shell]
    [HKEY_CLASSES_ROOT\dllfile\shell\runas]
    @="Take ownership"
    "HasLUAShield"=""
    [HKEY_CLASSES_ROOT\dllfile\shell\runas\command]
