Take Ownership Shortcut
Page 10 of 45 FirstFirst ... 8910111220 ... LastLast
  1. Posts : 48
    squall leonhart said:
    hmm, you're right, run as admin is broken D:
    but i know i had a self elevating take ownership item that worked fine with the run as admin command not so long ago.
    seems to be because it replaces the run as key for exe's.
    i recommend removal of take ownership over exe files?
    [-HKEY_CLASSES_ROOT\*\shell\runas]
    [HKEY_CLASSES_ROOT\*\shell\runas]
    @="Take ownership"
    "HasLUAShield"=""
    "NoWorkingDirectory"=""
    [HKEY_CLASSES_ROOT\*\shell\runas\command]
    @="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
    "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
    [-HKEY_CLASSES_ROOT\Directory\shell\runas]
    [HKEY_CLASSES_ROOT\Directory\shell\runas]
    @="Take ownership"
    "HasLUAShield"=""
    [HKEY_CLASSES_ROOT\Directory\shell\runas\command]
    @="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
    "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
    [-HKEY_CLASSES_ROOT\dllfile\shell]
    [HKEY_CLASSES_ROOT\dllfile\shell\runas]
    @="Take ownership"
    "HasLUAShield"=""
    [HKEY_CLASSES_ROOT\dllfile\shell\runas\command]
    Lol. I don't know. Just let me know when there is a new version to download that gives back the option to "Run as Administrator"
  2. Posts : 343
    theres no need to give it back, just use the packaged uninstall/removal file and that will restore run as admin.
  3. Posts : 48
    I guess what I'm trying to say, will it be fixed so that Run as Administrator and Take Ownership appear in the same menu so you have both options?
  4. Posts : 343
    doesn't seem possible to keep both run as options on exe files.
  5. Posts : 72,062
       #94
    Okey doke. The add REG download changed to not include "Take Ownership" for EXE files to leave "Run as administrator" instead. :)
  6. Posts : 48
    Hmmm... Ok. What if you just Take Ownership and run the file, will that give you the same permissions?
  7. Posts : 48
    So, what should I do to fix this? Uninstall current and redownload?
  8. Posts : 72,062
       #97
    You can run the Remove reg file to undo your current one and restore "Run as administrator" for exe files, then run the Add reg file for the new version. :)
  9. Posts : 48
    Works perfectly. Thanks.
  10. Posts : 72,062
       #99
    You're most welcome. :)
