Elevated Program Shortcut - Create for Standard User
Page 16 of 22 FirstFirst ... 61415161718 ... LastLast
  1. Posts : 72,055
       #150
    Jerome,
    If you run this .exe file in your administrator account, does it open the program you want the standard user to be able to?
  2. Posts : 925
    Windows 10 Pro
       #151
    No. The program doesn't seem to be your regular program, when I run the custom short-cut in the Administrator account, the CMD window, flashes open, closes, that's it. I may try to make the short-cut again, I don't have high hopes that things will be different the second time around !
  3. Posts : 72,055
       #152
    Yeah, if the program's exe won't run normally in your administrator account, then it will not work with this in the tutorial either.
  4. Posts : 925
    Windows 10 Pro
       #153
    The tutorial is useless for this program, arghhh any other suggestions ? I'll try one more time, if the same results, need an alternative.
  5. Posts : 925
    Windows 10 Pro
       #154
    When I run the short-cut within an Administrator account, it's not to say it doesn't work, the command window flashes extremely fast, open, then closes, that I'm unable to catch any error. Opening a command window then running the short-cut, still won't allow me to catch what the error is.
  6. Posts : 72,055
       #155
    Nar, I mean when you run the AsShellProcess.exe file itself instead in your administrator account, does it run. :)
  7. Posts : 925
    Windows 10 Pro
       #156
    Thanks for all your help Brink. After searching, I found some information from others experiencing the same problem. Unfortunately all the solutions, were unsuccessful. My only solution is to try a program that can do it, otherwise, I have to manually enter in the Admin password
  8. Posts : 72,055
       #157
    I hope that you find an alternative that works with that program.
  9. Posts : 925
    Windows 10 Pro
       #158
    I hope as well :) Thanks :)
  10. Posts : 925
    Windows 10 Pro
       #159
    If I mentioned this or not, the three programs I want to run at Start-up are in the Task Scheduler, I assume the installation of the programs did this automatically. Except I'm prompt for the Administration password when I restart the computer into a Standard account, this is what I want to overcome.
