#290
Icouldn't merge the .reg file
when I rirgt click to merge I didn't find it and when I went to set the assocciated file I didn't find the .exe file extention. pls advice
Hello Haithamsaadany, and welcome to Seven Forums.
The yellow TIP box under step 3 in the tutorial on the first page can help show you how to fix this to be able to merge the REG file afterwards. :)
I need an .mpq file to do this with, was hoping it could be added to the list please?
Hello GsNp, and welcome to Seven Forums.
By default .mpq files are not associated to be opened by anything. The REG file below will restore the default associations for .mpq files by unassociating them. After merging the REG file, restart the computer to full apply.
Hi Brink,
I cannot thank you enough for these file associations, you are a life saver
you just made my day
thank you so much for this post
Thank you very very much for sharing in this moment... my exe extension is openend with wrong program., and then i download from this forum so now i can klik my exe extension again eith good performance... Thanks bro n sist.. ^_^:):)
