Page 50 of 91 FirstFirst ... 40484950515260 ... LastLast
  1. Posts : 4
    WIndows 7 Ultimate x64
       #490
    Brink said:
    I would, but the problem is I do not know what program you originally had set to open .sav files with, or if was unassociated instead.
    I haved same image as .bin or .dat.And thought is the same thing.And i dont know to modify reg file.If you are nice,try to modify that .bin or .dat to .sav for me and put it for download.Thx.
  2. Posts : 72,094
       #491
    Ok Kidou. Here's a .reg file attached below for .sav for you to try. I hope it helps. :)
    Default File Type Associations - Restore Attached Files
  3. Posts : 4
       #492
    Thanks so much man.It have worked.Thanks you again!You're the best :)
  4. Posts : 72,094
       #493
    You're most welcome. I'm glad that it worked for you. :)
  5. Posts : 2
    Windows 7 Enterprise 32bit
       #494
    Hello Brink,
    I would like to restore the default associations of ".obj" files. Can you please add the relevant file to the list?
  6. Posts : 72,094
       #495
    Hello Sleiman, and welcome to Seven Forums.
    Sure thing. Added to list. :)
  7. Posts : 2
       #496
    Thank you Brink for welcoming me in the Forum...
    The ".obj" worked nicely... :)
    Cheers :)
  8. Posts : 72,094
       #497
    You're most welcome. :)
  9. Posts : 6
    Windows Vista
       #498
    I'm sorry if this is a dumb question, but when I download the .lnk extensions and choose "merge", it just opens in notepad and nothing happens. Am I doing something wrong? Thanks in advance!
  10. Posts : 72,094
       #499
    Hello Annieyea, and welcome to Seven Forums.
    It's not a dumb question at all. You will just need to do what's in the yellow Tip box under step 3 to restore the default association for .reg files. Afterwards, you should be able to merge it. :)
