Page 56 of 91 FirstFirst ... 46545556575866 ... LastLast
  1. Posts : 72,047
       #550
    Juan,
    Yeah, you'll need to restart the computer after merging the .reg file I posted above to apply it same as in tutorial. :)
  2. Posts : 3
    windows 7
       #551
    Hi Shawn,
    it worked like a charm and I also removed the string in ;
    HKEY_CLASSES_ROOT\sup_auto_file\shell\read\command
    It appears it still had the string for adobe acrobat reader.
    I now have the blanc notepad like icon again, thank you so much!!!!!!!!!!
    Juan.
  3. Posts : 72,047
       #552
    You're most welcome Juan. :)
  4. Posts : 2
    Hi -
    A friend of mine recently asked me to fix a broken keyboard on her laptop running Win 7 Home Premium. In checking it out, I found that the default programs for many file types were incorrectly set to Notepad. Using the Zip file collection of fixes from Brink's tutorial. I was able to fix most of them. A most sincere Thank You.
    However, three Security Certificate extensons, .cer, .crt and .der, which should use Crypto Shell Extensions, remain associated with Notepad. I don't know how significant these are as in the short time I have had the computer I don't believe I have seen any issues related to this. If you can help, it would be most appreciated.
    Finally, between your great tutorial and studying the reg files in your zip collection, I have started to gain some insight to the workings of the registry. Thanks again.
    Don
  5. Posts : 72,047
       #554
    Hello Don, and welcome to Seven Forums.
    The default .cer, .crt, and .der registry entries have been added. Hope they help. :)
  6. Posts : 2
    Shawn -
    That did the trick. Thanks for the prompt help and the great tutorials!
    Don
  7. Posts : 72,047
       #556
    You're most welcome Don. I'm glad to hear that they helped. :)
  8. Posts : 3
    Window7
       #557
    Hello, I had a problem that all my files and programs opening a ms word document format then I read the instructions and downloaded the extension types and I merged all the 105 extension files on my computer and I restarted the computer it was back to normal, I really appreciate this help but Are these secured extension files that I have merged in my computer, please let us know so that we can take precautions before we go head with our computer? I have some personal files on my computer so is there any hacking personal files from my computer? Why I am asking this because I am new to this forum and I don't have much knowledge, I just saw the instructions, downloaded the extension file types and merged in my computer? I am sorry If I am saying anything wrong. It is just for clarification.
    Thanks for all your help.
  9. Posts : 72,047
       #558
    Hello Stalin, and welcome to Seven Forums.
    I'm happy to hear that they were able to help you.
    First, I would strongly recommend in the future that if you are not sure of the safety of or have questions about a download, you should ask about them or scan them first before installing/merging on your computer so you will be safer.
    The downloads in this tutorial are 100% safe to use though. They will only restore the default Windows registry entries for the file extension that the download is for.
    Hope this helps, :)
  10. Posts : 1
    windows 7 ultimate x64
       #559
    hello
    i need (srt) file extension, it's translation file please, add it to your list reg
