Page 69 of 91 FirstFirst ... 59676869707179 ... LastLast
  1. Posts : 15
    Windows 7 home premium 64 bit
       #680
    what about .rar files?
  2. Posts : 72,051
       #681
    Hello phyys1x,
    By default, .rar files are not associated with a default program in Windows.
    If you wanted to unassociated .rar files, then you could use a method in the tutorial below to do so.
    If you wanted to assosicate a default program to open .rar files, then you could use either option below to do so.
    Hope this helps, :)
  3. Posts : 15
       #682
    The thing is, I cant change .rar files to open with winrar default, its added to open default on command prompt and I cant change back, what should I do?
  4. Posts : 72,051
       #683
    What happens when you right click on a .rar file, click on Open with -> Choose default program, select WinRAR, check Always use the selected program to open this kind of file box, and click on OK?
    Open With - Change Default Program
  5. Posts : 15
       #684
    I've tried to check the box but its not possible its like bright white so I cant press it
  6. Posts : 72,051
       #685
    I'll install WinRAR later today, and post back with a .reg file that will set .rar files to open with WinRAR by default. :)
  7. Posts : 72,051
       #686
    phyys1x,
    See if this may work you:
    1. Open WinRAR, and click on Options (Menu bar).
    2. Click on the Integration tab, check RAR, and click on OK.
  8. Posts : 3
    thanks, but icon not change. .:)
  9. Posts : 72,051
       #688
    Hello Bendot, and welcome to Seven Forums.
    More details please. :)
  10. Posts : 3
    icon in open with default program, but is work thanks
