Page 73 of 91 FirstFirst ... 63717273747583 ... LastLast
  1. Posts : 7
    Win 7 64 bit
       #720
    FYI, this worked for me on Windows 7 for the .bat extension. It broke on a Windows Update (???), but this fixed it. Thanks for the solution. It was for my backups scripts which I was in dire need of to get working again.
  2. Posts : 29
    Thanks again for these files! However can you add for "Unknown" files? This is
    the key
    HKEY_CLASSES_ROOT\Unknown
  3. Posts : 72,052
       #722
    the key
    Hello svnpenn,
    Added to the list. :)
  4. Posts : 29
    Thanks, you rock!
  5. Posts : 72,052
       #724
    You're most welcome. :)
  6. Posts : 6,458
       #725
    Hey Shawn,
    "Helped" on a thread where files without extensions would try to execute.
    Suggested .exe; .lnk; and Unknown - no change
    The member posted that they found and removed the following key, and the issue was resolved.
    I checked my machine, but the root class wasn't there, apparently it's associated with EA games
    Here's what they found:
    [HKEY_CLASSES_ROOT\Type]
    "PreviewTitle"="prop:System.Game.RichSaveName;System.Game.RichApplicationName"
    "PreviewDetails"="prop:System.Game.RichLevel;System.DateChanged;System.Game.RichComment;System.Displ ayName;System.DisplayType"
    [HKEY_CLASSES_ROOT\Type\Shell]
    [HKEY_CLASSES_ROOT\Type\Shell\Open]
    [HKEY_CLASSES_ROOT\Type\Shell\Open\Command]
    @="E:\\GAMES\\Origin Games\\Mass Effect 2\\MassEffect2Launcher.exe "
    I don't know if you want to include a Type reg file
    Here's a remove Type class, not a restore default
    ; https://www.sevenforums.com
    [-HKEY_CLASSES_ROOT\Type]
    Last edited by Slartybart; 02 Jul 2014 at 20:41. Reason: not dot unknown - thanks svnpenn
  7. Posts : 72,052
       #726
    Hey Bill,
    Thank you. Not sure how that affected the other file extensions either.
    I'll get it added now to restore blank file extension types.
  8. Posts : 29
    To be clear, it is not ".unknown" as you have put, but "unknown". Example
    HKEY_CLASSES_ROOT\unknown
  9. Posts : 72,052
       #728
    No worries. It's "Unknown" without the dot in the tutorial's download. :)
  10. Posts : 21,004
       #729
    Hello Shawn my partners laptop has gone crazy when she tried opening Pictures it asked how she wanted to open them and she picked Word and now all icons and programs have Word icons.
    When I click on them it opens a Word program and then a smaller window with what looks like gobbledegook language in it.
    I cannot even get to system restore as even it opens with Word is there an easy way around this??
