Page 76 of 91 FirstFirst ... 66747576777886 ... LastLast
  1. Posts : 72,051
       #750
    No worries. :)
    You would basically right click on a .py file, click on Open with, and either select the pytivo program, or click on "Choose default program" to browse to and select the .exe file of the pytivo program.
    Clicking on the link in my post above will give you more details to further help.
  2. Posts : 8
    win7 Home 64
       #751
    Sorry didn't notice we had created another page
    Therein lies the problem. The .py file is the executable so I can't really tell it to open with itself.
  3. Posts : 72,051
       #752
    In that case, you could do a system restore using a restore point dated before it was changed to undo it.
  4. Posts : 8
    win7 Home 64
       #753
    A system restore seems drastic. There is no way to designate .py files as executable? Seems like such a small problem to warrant a restore
    Plus it looks like my system restore doesn't go back far enough.
  5. Posts : 72,051
       #754
    Nar, a system restore would be perfect to quickly undo a recent action. It's not a factory restore, but just a quick undo to a restore point. The link above will give you more details if needed.
    Wouldn't you use a program like Python to open a .py file with?
  6. Posts : 8
    win7 Home 64
       #755
    I have no idea how it functions with python but whatever it does it is supposed to start a service to transfer files between my computer and tivo. I am in no way savy about how software works but the file itself is very small so I just think it is a script to start the services necessary to make the magic happen. My latest restore only goes back a month and I've had this problem for almost 4.
  7. Posts : 72,051
       #756
    If you like, you could try downloading and merging the .reg file below to completely unassociated .py files, then restart the computer to see if that may help.
    If not, then reinstalling whatever you installed originally for use with .py files should restore it.
    Default File Type Associations - Restore Attached Files
  8. Posts : 8
    win7 Home 64
       #757
    Bam that seems to have done it.
    You my friend are a genius. I will test it out in the morning but it looks like the service started right up.
    I owe you a beer :)
  9. Posts : 72,051
       #758
    Great news.
  10. Posts : 67
    Windows 10 Pro Insider Preview + WSL2
       #759
    mkv - A Matroska Multimedia Container file is a video format [...] This download will set this file extension back to the default unassociated state in Windows 7.
    Thanks a lot! I was getting crazy trying to get mkv files associated with mplayer2. Mkv was missing from file types list and mplayer has no options (portable binary)
