Page 89 of 91 FirstFirst ... 798788899091 LastLast
  1. Posts : 1
    Finally, after looking through whole internet I've found this tutorial.
    I had problem with .pdf and .docx. I downloaded .reg for .pdf and edited it to suit .docx files by changing 3 lines in .pdf reg file. Simple and works perfectly.
    Thanks, Brink.
  2. Posts : 72,061
       #881
    I'm glad it could help Globoo, and welcome to Seven Forums. :)
  3. Posts : 496
    Windows 7 SP1 Home Premium 64bit [x64]
       #882
    Hi Brink.
    I think you need to add SYS or "System File" extension to your list of Default file extension type associations.
    I'm recently fixing my cousin's HP pavilion dv6648se laptop with Win7 Home premium 32bit and some of the file type associations are messed up, including the DLL and SYS file types. the DLL & SYS file types seem to be opening up in Adobe Acrobat Reader DC as default, which is incorrect and I need to reset them or "un-associate" them from Adobe.
  4. Posts : 72,061
       #883
    Hello erpster.
    SYS has now been added to the list.
  5. Posts : 1
    Windows 7 Ultimate x32
       #884
    Hello,
    I'd be very grateful if you could add the CRL file extension to your list so that it is available for restoring to default.
    With thanks in advance,
    Marina
  6. Posts : 72,061
       #885
    Hello Marina, and welcome to Seven Forums.
    CRL has been added to the list. I hope it helps.
  7. Posts : 1
    Windows 7 Enterprise x64
       #886
    Hi Brink,
    there seems to be an error in the .reg file for ps1:
    Line 46 says [-HKEY_CLASSES_ROOTS\SystemFileAssociations\.ps1] (note the superfluous 'S' in ROOTS).
    Since it seems to work without this, maybe deleting the key at all is superfluous :)
    (The key HKEY_CLASSES_ROOT\SystemFileAssociations\.ps1 doesn't even exist for me, even though I changed the default file association.)
    HTH
    Marcus
  8. Posts : 72,061
       #887
    Thank you Marcus, and welcome to Seven Forums.
    The .reg file for ps1 has now been fixed.
  9. Posts : 1
    Windows 7 Enterprise x64, Windows 8.1 x64, Windows 10 Pro x64
       #888
    Just registered to say THANKS!
    Fonts behaving normal again...
  10. Posts : 72,061
       #889
    You're most welcome, and welcome to Seven Forums.
